Roughly how much to replace a gearbox? - Defender Source
Old January 20th, 2013, 05:35 PM
Gordonhurst
Mark
Looking at a D90 which has over 220K miles on the gearbox. If I buy it and end up having to replace the gearbox, roughly how much would that cost me? The engine's more recent, but what else would I have to worry about with regard to the running gear, and how much could those repairs cost?
I realize this is a bit of a "how long's a piece of string" question, but looking for ranges.
Thanks, all
Old January 20th, 2013, 05:42 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I believe ATL cruisers charges $1600 or so based on a thread I saw recently.
Old January 20th, 2013, 05:48 PM
Gordonhurst
Mark
Forgot to mention. The engine was upgraded to a 4.6L approx. 50K miles ago but the gearbox was not altered. Should I be concerned that the extra power/torque of the larger engine could cause problems to the gearbox that's now seen 220K miles?
------ Follow up post added January 20th, 2013 05:50 PM ------
Tony, does the $1,600 include parts and labor?
Old January 20th, 2013, 06:02 PM
Definitely not. Expect to pay about $1750 for a new trans.
Old January 20th, 2013, 06:07 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Plus clutch bits, if there is any doubt about their condition.
1970 SIIA 88, Sold
Old January 20th, 2013, 07:24 PM
Definitely replace clutch and pressure plate while you're there.
Old January 20th, 2013, 07:38 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Unless you know the clutch has like low miles, always replace it (clutch flywheel kit) whenever you pull the trans, considering the time the job takes, took me 5.5 hours on my 4runner with good tools and lift to pull trans+t-case and put new clutch in. I'd expect a shop to want around $1k to change the clutch, and considering that is the exact same job as changing the trans you are looking at around $1k plus trans cost.
Old January 21st, 2013, 04:39 PM
Gordonhurst
Mark
Thanks, guys. the clutch was replaced 30K miles ago, so should be OK. I just wanted to confirm that the $1,600 to $1,750 range for the gearbox included parts and labor.
Best
Old January 22nd, 2013, 12:34 AM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Best
I just bought a rebuilt gearbox & it was $1600 alone. From my experience to have a shop do the gearbox you'll be looking more along the lines of $3k - $4k parts & labor w/ gearbox. -- this isn't factoring in all of the issues that they can find when they pull the gearbox. Don't estimate on the lower end, plan for the higher end.
Old January 22nd, 2013, 04:11 AM
sro
Sam Odio
2008 LR2
I get that when replacing the tranny it's good to do the clutch too. But what if you need to replace the clutch? Does it make sense to spring and rebuild the tranny?
Old January 22nd, 2013, 08:35 AM
a clutch disc is cheap- around 50-70 dollars. Saying one is fine because it only has 30k on it seems misguided. Replacing the disc and throw out bearing will cost less than an hours labor when added on top of the trans remove and replace.
I replaced mine when it only had 20k because I was there.
Old January 22nd, 2013, 08:47 AM
The Dro
Dro
1988 Ninety
Not on a R380. If it were a ZF 4HP22 it's a different story.
Old January 22nd, 2013, 09:55 AM
malaD90's Avatar
malaD90
Paul
1994 D90 ST
Last year I had my tranny and gearbox rebuilt and clutch replaced for about $4300. It all started with a tranny leak and kind of blew up from there, but I am much more comfortable beating it on the trail now. You will likely find some other bits underneath that need replacing when your mechanic gets into it.
"Beer has food value, but food has no beer value."
ac
I've broken my gearbox!!! mikeslandrover Defender Technical Discussions 6 May 29th, 2006 05:04 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
General consensus question 4.0 or 4.6 to replace 3.5 draaronr Defender Technical Discussions 18 August 19th, 2004 05:25 PM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
How hard to replace a Transfer case? crash0577 Defender Technical Discussions 1 October 7th, 2003 08:40 AM
