rockware diff guards - Defender Source
Old July 16th, 2010, 10:06 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Does anyone use these? Are there any problems with welding them on? If you have been using them are you happy with them?
That is why it is called a short cut. If it was easy it would just be "the way."
Old July 16th, 2010, 10:19 AM
The sewer caps? Work great! You do need to have a competent welder do the welding, otherwise it will leak.
Old July 16th, 2010, 09:06 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Does your front leak?
Semper Fi!
Old July 16th, 2010, 09:55 PM
D90DRC
D Cantrell
1997 D90SW
I think he meant burn a hole in the thin stock housing thus allowing axle lube to leak out...
Still waiting for the Hope and Change to start
guards
« Roav | Whats worse »
welding diff guards rover4x4 Defender Technical Discussions 6 March 26th, 2006 03:50 PM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
110 rear diff protection (Salisbury diff guards) dave_lucas The Vendors Loft 13 October 25th, 2005 09:08 AM
diff guards and discovery rubber floor mats ToaDisco For Sale - Parts 5 June 5th, 2005 10:54 PM
Flex-a-lite 210 & Qt Services Diff guards Chaucer For Sale - Parts 6 April 1st, 2005 10:35 PM
