Replacing 110 2 door fixed windows with sliders - Defender Source
Old July 22nd, 2015, 06:36 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have been researching replacing the fixed windows in our 110 2 door hardtop with double sliding units.
Boat Windows, Rv Windows | Motionwindows.Com
Will build any custom size window.
The "African Roof Sides" have twin fixed windows about 39" X 11.5 that would cost roughly $250 each delivered to VA.
Anyone have any experience with Motion Windows?
They make to order with a 6 to 8 week lead time.
RDavisinVA
Old July 24th, 2015, 08:33 AM
LR Max
Thomason, Max
1973 Series 3 109
Those might be the windows in my new-to-me 109 sides.
When I get home I'll look at the brand. Then again they are 20 years old.
BTW sliding windows in a 3 door LWB is pretty much the greatest thing to ever.
Old July 28th, 2015, 07:37 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Agreed!
RDavisinVA
Old July 28th, 2015, 08:19 PM
I have a set of 110 sides on my 109 that use the same sliding windows as my 90. Not a factory window but a type that looks correct for LR and I believe is the same size as the LR cutout.
I can go look and see if there is any identifying marks. $500/side seems high.
I think these are the ones.
http://www.britpart.com/all-parts/da4032/
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 29th, 2015, 06:47 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Have you looked at the options from Rimmer Bros?
Sliding Window Kit products at rimmerbros.co.uk
Old July 29th, 2015, 07:29 AM
I like those matching double side windows better than anything I've seen before in a 110 HT.
Old July 29th, 2015, 07:40 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
When you already have fixed windows, it becomes a custom application because standard OEM Rover windows don't fit in the hole left when a fixed window is removed.
This requires a custom window the same size or larger, but NOT smaller like the Bearmach or Britpart ones.
You have to fill the hole left when the fixed window is removed.
The custom ones from Motion windows are the only ones that I have found to order that will work.
Years ago I had 4 Series sliding panels cut up and re-welded to form 2 double sliding roof sides.
The result was nice, but the almost all windows like this one will be.
If you had solid panels, well that is a blank canvas for whatever you want to fit.
RDavisinVA
110, ac, windows, window, door, slide
Replacing molding between the door and windows pdella Series Technical Discussions 13 June 20th, 2012 03:02 PM
110 3-door sides w/ fixed windows $100 Jackie Treehorn For Sale - Parts 3 December 21st, 2011 07:07 AM
How to access Bulkhead Door Hinge Bolt Fixed nut bd90 Defender Technical Discussions 15 April 8th, 2010 01:44 PM
Passenger side sliding rear window for a 90 or 110 roofside and one fixed window evilfij For Sale - Parts 2 June 2nd, 2009 10:46 AM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
