Redline "Water Wetter" - Defender Source
Old December 16th, 2009, 02:57 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I have used this product in the past on my other Toyota trucks with antifreeze also, I have noticed a slight cooling in temps.
But has anybody used it with purified water & Water wetter as recommended by the manufacture in there truck?
Mine has been running a little hot in the afternoon & was thinking of using purified water & Water wetter as a test as per the specs will provide better protection & eliminate air pockets if I read everything correctly on the product label.
Old December 17th, 2009, 06:00 PM
there was a thread on this a while back, I dont think it works.
Old December 18th, 2009, 02:01 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I tried it in 50/50 coolant. It does nothing.
However, it has enough lubricity that you can run straight water and not have your pump go out. Water has twice the heat dissipation as antifreeze, so if you use it with only water it will deliver results. So in FL where it never gets below freezing, you should be fine.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 18th, 2009, 08:47 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I used it with water in Georgia summer and found very little benefit. Supposedly it is a surfacant that allows the bubbles to form in smaller clusters that maintian a greater surface area of water contacting the metal surfaces to disipate heat but in a practical nature, I found no difference.
It surprises me the number of companies that make a lot of money selling additives that are of little or no value. Redline makes some good products for reducing pinging in diesel engines but water wetter is a pass.
Old September 20th, 2010, 12:34 PM
I have ran this in my Classic since about the middle of the summer, it has been running a hair cooler based on the VDO gauge and its been hotter than a mother here in NC.
Old September 20th, 2010, 02:24 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
You are correct, I found very little improvement,...went back to 50/50 antifreeze...
Old September 20th, 2010, 02:41 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
You have to use it with straight water or you are wasting your money.
Old September 20th, 2010, 02:50 PM
X2 thats how Im running it
Old September 20th, 2010, 03:43 PM
D90DRC
D Cantrell
1997 D90SW
Keep it for track and off-road only it's worthless on the street
Still waiting for the Hope and Change to start
Old September 20th, 2010, 03:56 PM
elaborate please
water
Redline and shift points sflash868 Misc. Chit-Chat 13 December 17th, 2009 08:52 AM
Good Alternative to Redline for transmission advnirvana Defender Technical Discussions 12 July 5th, 2009 10:13 PM
Redline MTL users rover4x4 Defender Technical Discussions 0 April 8th, 2007 08:16 PM
redline MTL jstrong98 Defender Technical Discussions 15 December 6th, 2005 12:59 PM
Redline Lubes Question JimC Defender Technical Discussions 3 April 12th, 2004 02:42 PM
