Recreating the weathered patina? - Page 2 - Defender Source
Old February 11th, 2015, 04:25 PM
giftshopduane
Chris luciano
72 Series 3 88"
I think you'd have to thin the paint, and lay down a very thin coat then wet sand with a very fine grit, lots of water. I wouldn't prime it first though, if you did I'd use a primer tinted the same as your topcoat, again super thin coat. Do some research on how these weather and sand with a plan so it doesn't look haphazard. Once you are satisfied I'd still consider polishing in some areas especially where the birmabrite shines through,my series 3 is a little shiney at the bear metal, also the buffer if used with a heavy hand can feather in the bare spots. It's doable, I'd practice with a spare part or the hood first, easy to strip and retry.
What I wouldnt do is use a media blast of some sort as it will leave a tooth in the aluminum and it will not replicate the smoothness the birmabrite has inherently.
Old February 11th, 2015, 04:30 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
You have to be real careful with recreating patina as it's so easy to fudge up. Reminds me of the guitars that are "relic'd". I haven't seen one come close to an authentic worn by time patina.
Glenn
Old February 11th, 2015, 04:52 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
paint it then hit (lightly) with 1000 grade wet&dry with a dash of pure soap and lots of water, no dishwasher soap.
Good idea with the tinted primer as somebody else said on here.
instant patina
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 11th, 2015, 05:07 PM
BlackField's Avatar
BlackField
Oscar
D110
metal oxide flake in the paint let it sit. clear coat over it when done. mmm rusterific!
Old February 11th, 2015, 05:08 PM
I used rustoleum camo with Matt clearcoat currently only on some panels not all.
Old February 11th, 2015, 05:20 PM
Tino.R's Avatar
Tino.R
Tino Rebelo
67/series IIA
Originally Posted by hmmrbrg View Post
That looks like it could do the trick. So Rustoleum spray paint? You sprayed the whole vehicle?
Yes spray cans.Striped ,two coats of etch primer and three coats with a can.
Old February 11th, 2015, 05:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by evilfij View Post
If you can find a complete body with the look, patina with galvanized bulkhead is a good look.
I am going for that look. I hate to say "look" but I just want the body to be no-frills and for me not to worry about it. My truck had a half ass paint job in the UK (complete with plenty of over spray) and has a darker blue over the original Marine Blue. I would love to be able to sand/buff/feather the top layer a bit to expose the original paint.
Old February 11th, 2015, 07:20 PM
Ron Thompson's Avatar
Ron Thompson
Ron Thompson
1966 Series 2a
Here's an example that was painted with flat paint and left to marinate
Old February 11th, 2015, 07:25 PM
hmmrbrg
HMMRBRG
1972 SIII 109
Pure awesomeness. At least in the picture. I'll try this route.
Old February 11th, 2015, 07:39 PM
Dale, may I ask what brand of paint? This is where I am headed and this is gorgeous!
Originally Posted by rovertrader View Post
We are just finishing this one, fresh but original single stage. And it is headed to St Petes , Fl so will be patina'd quickly ;-)
Originally Posted by pendy
I'm here for the D's
Old February 13th, 2015, 07:40 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
You want patina? I got your patina right here:
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old February 13th, 2015, 07:46 PM
rovertrader's Avatar
rovertrader
Dale
I'll have to check with the painter Charles- he has been doing the local dealership's work for near 30 years.
ecr
Once again - Arles blue hood and left front fender, need patina smob Wanted 0 April 12th, 2013 09:35 AM
Used “patina-ed” Series metal badge – For Sale HeloBubba For Sale - Parts 3 January 12th, 2013 01:37 PM
Warn 8274, older, serviced, shows patina ItsNotAJeepThing For Sale - Parts 2 August 27th, 2012 05:11 PM
