Recovory Lines - think outside the box - Defender Source
Old December 2nd, 2014, 12:14 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Consider premade dock lines for 1/2 the cost. For example, this 3/4-inch dia x 35-ft should to the trick: http://www.defender.com/product3.jsp...894&id=1410964
You can go up to 1-1/4-inch and 41,000 lbs if you feel the need. Save even more $$ by just purchasing the line and learning to tie a bowline.
Ironic that one of the bigger boating supply stores is www.defender.com
Old December 2nd, 2014, 12:18 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
What kind of recovery are you using this for, dynamic or static? Are you using it on a winch or just as a snatch strap?
Old December 2nd, 2014, 12:20 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Done & Done...
Old December 2nd, 2014, 12:42 PM
down_shift's Avatar
down_shift
Russell
Using as spring lines on my 15,000 lb boat which would be dynamic.
Old December 2nd, 2014, 12:43 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This.
Considering it says this "Excellent stretch and abrasion resistance " I would think this is a recovery rope not a kinetic rope, which means the price is on par with a normal recovery strap.
Still a nice looking bit-o-kit, my only concern is someone mistaking it for a kinetic rope and giving it hell.
EDIT: Just saw the heading "combining high strength with good flexibility and shock absorption"
So maybe it is a kinetic style rope? Good deal if so. Somebody buy one and try it out.
Old December 2nd, 2014, 01:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It's important to know what kind of stretch it provides. 18k is not a lot if you're doing dynamic recoveries. If those prices are good for kinetic ropes, that's great. Personally I wouldn't want anything with less than 20% stretch for kinetic recoveries.
Old December 2nd, 2014, 01:18 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by down_shift View Post
Consider premade dock lines for 1/2 the cost. For example, this 3/4-inch dia x 35-ft should to the trick: http://www.defender.com/product3.jsp...894&id=1410964 You can go up to 1-1/4-inch and 41,000 lbs if you feel the need. Save even more $$ by just purchasing the line and learning to tie a bowline. Ironic that one of the bigger boating supply stores is www.defender.com
I bought my winch line from these guys about 9-10 years ago. The line has been used and abused with no complaints.
Old December 2nd, 2014, 01:20 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
What on the market has a 20% stretch?
Old December 2nd, 2014, 01:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Our kinetic rope, ARB's kinetic strap, Marlow's, Bubba rope - all have 20% or more stretch.
Old December 2nd, 2014, 01:37 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Yeah I thought it was closer to 30%
Old December 2nd, 2014, 01:45 PM
The one linked above is a nylon line and it will have a lot of stretch.
Old December 2nd, 2014, 01:54 PM
87 D110 (Ruby)
My son can attest to the fact that using a recovery line and tying a bowline in it is NOT a good idea! Now, he was trying to pull a tree out...but....not recommended.
Old December 2nd, 2014, 01:56 PM
Because that is the incorrect knot......
Old December 2nd, 2014, 02:22 PM
down_shift's Avatar
down_shift
Russell
The double braid nylon ropes by Buccaneer conform to MIL-R-24050D. Elongation is covered in Section 3.5.1 that states "...shall not exceed 40% at the minimum breaking strength..." I didn't see a requirement for a minimum stretch. But I can assure these lines stretch just fine.
Bubba Ropes says mil spec, but does not appear to cite one. However, the following Bubba elongation chart shows a 30-35% elongation at break (note, within the 40% mil spec above). http://www.bubbarope.com/rope-facts
Don't get sucked into the marketing and hype to justify paying 2-3x more. If people trust Buccaneers lines to keep their $$$$ boats from getting smashed during a northeaster, I an assure you they will work fine in jerking your buddy's rig out of the mud hole. The loading conditions are about the same. Go to your local marina during a storm and then tell me what puts more stress on the ropes.
Old December 2nd, 2014, 02:29 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'm not suggest not buying this rope, just wanting to makes sure it's correct before anyone gets disappointed! Sounds like a good rope
Old December 2nd, 2014, 02:35 PM
down_shift's Avatar
down_shift
Russell
?? The bowline is the best general purpose high strength knot around. Bonus it that it is easy to tie and easier to untie. Even the FAA recommends the bowline to secure aircraft. Yes, the bowline reduces the line strength by ~ 35% as do all knots. Thinking the best knots are around 20-25% but those require a specific condition (like wrapping around a 2' dia tree ...). To make a quick looped end that needs to be untied later, it is hard to beat the bowline.
Somehow a Pedro reference needs to be worked in the discussion.
Old December 2nd, 2014, 02:39 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
A line splice is not a horrible task to under take. Largest size I ever did was 8" and used a capstain to cinch it down...
http://www.jamestowndistributors.com...t.do?docId=921
Old December 2nd, 2014, 02:44 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Where's the 1-1/4" lines? Couldn't find them on the website.
Old December 2nd, 2014, 02:57 PM
tjfslaughter
thomas
Burbon
ever heard of the dragon bowline?
Old December 2nd, 2014, 03:03 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Coming from the climbing community, I have played with a lot of knots. Knot strength is partially dependent on the type of rope-- that said, the bowline is a decent utility knot that ties and unties easily and has a fairly decent knot strength for being easy to tie/untie--it weakens the rope typically in the 40% range. There are better knots, such as a figure eight (also fairly easy to tie/untie) or a blood knot that are quite a bit stronger. None of these compares to a properly braided end which which is what you find on commercially available snatch straps. I don't use knots unless there is a good reason
Genuine Land Rover Thule Box (pick up only outside philly) $120 evilfij For Sale - Parts 2 April 12th, 2009 11:17 PM
Carnage Canyon outside Boulder this Sat. tbmcneill Misc. Chit-Chat 0 October 25th, 2005 10:42 PM
rear view mirror - outside scoloco Wanted 3 May 19th, 2005 04:55 PM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
outside mirror bolt size ?? norros Defender Technical Discussions 14 May 9th, 2004 06:58 AM
