Recovery points - Defender Source
Old December 4th, 2013, 09:02 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Recovery points
I have a Southdown steering guard with recovery points integrated in on the 110. I was recently told that they would work fine as recovery points on their own but just by looking at them it seems to me like I would only use them with a bridle. Anyone have any experience with how stout these actually are?
"These are the best traveled nuts on d-90 . . ." ABrooks
Old December 4th, 2013, 09:09 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Nope. Not Jate rings. Integrated recovery points on the Southdown steering guard.
Old December 4th, 2013, 09:13 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Like these.
Old December 4th, 2013, 09:33 PM
Southdown never made a guard with recovery points.
Old December 4th, 2013, 09:42 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
My bad. It's a TerraFirma. Had Southdown on the brain for some reason.
Old December 4th, 2013, 09:46 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Southdowns site is down due to hackers! That's odd...(sorry off topic)
Old December 4th, 2013, 09:47 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Has been for a while
Defender 110
Old December 4th, 2013, 09:58 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
http://www.lucky8llc.com/Products.as...40#prettyPhoto
Here's what I have.
Old December 4th, 2013, 10:46 PM
ArlowCT's Avatar
ArlowCT
Ryan Lowe
1973ish SER III, 88"
What type of material is that? It looks like 1/4 or 3/8 aluminum. If that is true I would not trust it. If it's steel, it would depend on how thick it is and what type if recovery it was.
Old December 4th, 2013, 11:21 PM
It's steel, probably 1018 or a36.
Old December 4th, 2013, 11:31 PM
C391HAT's Avatar
C391HAT
Zach
86 110
Would also like to know as I have one waiting to go on my 110 when I finish my rebuild. Just measured mine and it was 0.315" thick and there was 0.40" of material from the hole the the edge. They also make an alloy version too.
Old December 4th, 2013, 11:50 PM
I'd really vote "no way". If you need a small tug *maybe*, but the last time I got recovered Huff had to get a running start with both of his lockers on and we managed to bend my SG 2" receiver plate that is like 3/4" thick.
This was it:
Old December 5th, 2013, 12:14 AM
C391HAT's Avatar
C391HAT
Zach
86 110
This was it:
Out of curiosity, how was your rear crossmember after that? I feel like more than just thickness has to be considered here. Things like the geometry and how the forces are distributed.
Old December 5th, 2013, 12:25 AM
Rear cross was absolutely fine, receiver took the brunt. But I'd say back to JPs original inquiry either get a proper winch bumper, or I saw some brackets made by COR4 (the new Equipe) that bolted into the frame horns and had swivel shackles and were heavy duty (but they were pricey). That, or just put a strap on your front axle and I'd recover on that no problem!
Old December 5th, 2013, 12:43 AM
C391HAT's Avatar
C391HAT
Zach
86 110
That's kind of what I was wondering about with the more than just thickness thing. The steel on the crossmember is only a couple mm thick yet it held up to enough force to bend the 3/4" steel receiver
Old December 5th, 2013, 07:20 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
Did we ever determine what the optimal front winch bumper was?
I recall receiving an email with pictures of about 20 different bumpers. What did you get?
Old December 5th, 2013, 08:13 AM
This was it:
1) couldn't he have winched you?
2) were there any other vehicles around that could have assisted the anchoring or the actual pull?
D) does the SG plate bolt to the bottom of the crossmember at all, or just the face?
54) were you using a regular strap or a kinetic rope?
Cow) Are you still using the SG plate?
Horse) Do you have any pictures? Just curious.
LLama) If you've read this far...
Old December 5th, 2013, 08:26 AM
Big fan of using a bridle and kinetic ropes. The kinetic's give is key to avoiding shock loads on the vehicles involved.
Old December 5th, 2013, 09:11 AM
87 D110 (Ruby)
better to ask Lav how his neck was
Old December 5th, 2013, 12:17 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Steel
cover
Front Recovery Points loykd Defender Technical Discussions 48 May 7th, 2010 09:30 PM
Front recovery points (long) GaryBaxter Defender Technical Discussions 20 August 19th, 2007 08:00 AM
Equipe Swivel Recovery Points RedRhinoProducts For Sale - Parts 7 March 17th, 2006 06:01 PM
Recovery points on LR winch bumper? jam90 Defender Technical Discussions 18 October 18th, 2005 08:06 AM
Help, what kind of front recovery points UpnOver Defender Technical Discussions 7 July 5th, 2005 12:40 PM
