Recomendation for 2 post car lift - Page 2 - Defender Source
Old June 2nd, 2014, 09:38 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
My buddy has the portable 2 post lift system by MaxJax. The hydraulic pump operations off 110v.
http://www.maxjaxusa.com/index.html
http://youtu.be/QSUAXQOoXuY
It is not the A++ commercial stuff Jimmy lists above, but you can get the MaxJax shipped for about $2000 when on sale. It works very well. Limitations are its 4-ft height and 6,000 lb max weight. If/when I purchase a lift, it will be this system due to its low cost and portability.
Here is the MaxJax. Random pic off the web:
------ Follow up post added June 2nd, 2014 09:44 AM ------
Regardless of the lift, be careful. Don't be this guy.
Old June 2nd, 2014, 10:55 AM
jafir's Avatar
jafir
Jafir Elkurd
Two friends of mine, brothers, and I went in 1/3's in a bendpak lift for their dad's shop. It's pretty cheap, works well enough for what we need. I've put D2, LR3, and my 90 on it. I
usually put a pair of tripods under the 90, one under the rear crossmember and one under the front one or the bumper, just to keep it a little more stable and keep from rocking front to back.
Similar on the D2's:
The arms are so close together, I like to have the extra support so it doesn't rock off the lift.
Old June 2nd, 2014, 11:10 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
who says you need a lift for a chassis change? I for one would never use or allow anybody to use a two post lift on any of my vehicles.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 2nd, 2014, 11:13 AM
down_shift's Avatar
down_shift
Russell
Everyone has their reasons. What is yours?
Old June 2nd, 2014, 11:17 AM
Keep in mind, if you get a two post lift, you must have suitable concrete. They rely of solid floor anchors. Most residential garage slabs are not adequate.
Old June 2nd, 2014, 11:21 AM
I'm looking for less expensive options.
We could build this for you in like a weekend for a bit less than $2k, we'd just need a longer ramp for the 110s.
Name:	Jarek M Lift Ramp.jpg
ID:	96159   Click image for larger version
Name:	Jarek M Lift Ramp 2.jpg
Old June 2nd, 2014, 11:44 AM
that's a 4 post equivalent ... i need a 2 ... I want the suspension to hang down.
There won't be any 110's going on my lift ... ;-)
Old June 2nd, 2014, 11:48 AM
You can get jacking bars for 4 posts lifts to unload the suspension.
Old June 2nd, 2014, 12:04 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
4 post are still a pita seems the rails are always in the way. Ok for changing oil and stuff like that but suspension / brake / trans are just awkward.
I would still take one over no lift at all but hate using them
Old June 2nd, 2014, 12:06 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
When not in use it could double as a pool deck platform!
Old June 2nd, 2014, 12:42 PM
That would not help for a chassis swap.
Battery recomendation DucatiChick Defender Technical Discussions 135 February 22nd, 2016 05:50 PM
Mechanic recomendation Monmouth cnty NJ? yeahbuddy Series Technical Discussions 2 January 19th, 2012 02:10 PM
New suspenson recomendation Chris Velardi Defender Technical Discussions 4 March 2nd, 2011 10:31 AM
Needed-shop recomendation in Milwaukee Uncle Douglas Defender Technical Discussions 3 December 14th, 2009 06:36 PM
Thermostat recomendation kellymoe Defender Technical Discussions 2 March 22nd, 2008 04:24 PM
