Reburbished my badge - Defender Source
Old June 25th, 2012, 12:24 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Tackled a small project this weekend. My badge was faded and looking sad compared to the rest of the truck so a removed it painted it and sanded down the raised areas with 100 grit. Easy DIY job. I painted the 3/16th rivets black after it was installed, but left the stamped numbers black.
Old June 25th, 2012, 12:29 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
looks good!
Old June 25th, 2012, 01:31 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Thanks! Sometimes the easiest jobs make the biggest difference in appearance.
Old June 25th, 2012, 01:34 PM
rusty james's Avatar
rusty james
Rob
95 D90 SW
Nice!!
Old June 25th, 2012, 01:40 PM
DOX's Avatar
DOX
Eric Doxey
1995 Defender 90
looks great
Old June 25th, 2012, 01:43 PM
Mpfish82's Avatar
Mpfish82
'94 AA Yellow D-90 #690
What kind of paint did you use? My badge is in need of some love as well. You worrying about the raised portions corroding after you sanded them or did you use a clear coat?
Old June 25th, 2012, 02:20 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
I thought of using clear coat, but didn't. If others have done this and had the aluminum corrode, let me know. I'll tape it off and clear coat it in place if needed.
After wire brushing and cleaning with mineral spirits I used self etching primer and Krylon semi-gloss. Sanded it down after one and a half hours.
Old August 13th, 2017, 07:10 AM
Bostondave
Dave
97 D90
Has anyone else cleaned up their badge like this or perhaps another technique? The badge on my truck is oxidized and I'd like to clean it up. I've tried cleaner wax but it's a pita trying to get at the parts around the wording.
Old August 13th, 2017, 11:48 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Might try rubbing compound on a drill buffer
Old August 14th, 2017, 06:07 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Very nice! Always a good idea to check the back for corrosion. The back of mine was a white crumbly mess. I got all the corrosion off with the wire wheel and painted the back black.
Old August 14th, 2017, 06:33 PM
Bostondave
Dave
97 D90
Chip - Did you drill out the rivets and remove? If so would you briefly share an overview? I've never drilled out or used rivets before.
Old August 14th, 2017, 06:45 PM
Chip's Avatar
Chip
Andrew
Yeah rivets are great. They're 3/16" so you can use that size drill bit to remove them. You could start out with one that's a tad smaller if you'd like. The rivets are blind sealing type aluminum with a steel mandrel. They're pretty inexpensive from McMaster-Carr. The two common lengths are 0.45" and 0.575" LNG on these trucks (.188"-.25" & .313"-.375" material thickness). The badge is kind of thick so you could use the longer one. It's easiest to use a pneumatic riveter. The one from Harbor Freight works just fine. If you'd like a black rivet the LR part number is RRC4583. The parts catalogue specifies those for the badge on the 50th trucks.
Old August 15th, 2017, 08:06 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Looks really good.
RDavisinVA
Bloody Knuckles Pub Badge Wanted / Show Off Your Grill seriesgarage Wanted 34 July 31st, 2013 09:30 PM
NAS POE D90 Badges/109 Badge lrnasd90 For Sale - Parts 19 March 20th, 2012 10:02 AM
Bloody Nuckles badge or similar... dogbite Wanted 20 March 1st, 2012 08:04 AM
Roav bronze badge Rugbier For Sale - Parts 6 August 21st, 2011 08:22 AM
50th anniversary badge? cwilder Defender Technical Discussions 5 May 18th, 2010 04:20 PM
