Rebuilt air flow meters MAF only $160 - Defender Source
Old March 7th, 2006, 10:52 PM
Antonios
Antonios Hadjigeorgalis
No more
I might need one and I started looking on the web. found this site:
http://store.yahoo.com/dpstore/afmakr2.html
I don't know anything about the company as I haven't ordered or spoke to them.
Miami, FL
Old March 8th, 2006, 01:24 AM
willtillery
WILL TILLERY
TO MANY ROVERS
maf
HOPE they are good....kind of scarry how they are selling 97 folks the same as 94-95
Old March 8th, 2006, 08:28 AM
Antonios
No more
Well it should be correct for the 94/95 as they have the same part# listed for 94 discovery, rang rovers and 93 D110. If I find out mine needs replacing I'll give them a try and report back.
Miami, FL
Old March 8th, 2006, 09:54 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
All the US based defenders/rangies/discos are V8. I don't know if you can use the 6cyl version--try it if you want, though.
Old March 8th, 2006, 10:08 AM
Antonios
No more
I'm pretty sure that's a misprint. It says 8cyl under some of the other vehicles.
Miami, FL
Old March 8th, 2006, 10:18 AM
Must be a misprint, when were there ever any 6cly Rovers?
Old March 8th, 2006, 02:51 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Doesn't specify..... is it a Lucas AM5 or an AM20? VERY different parts.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 8th, 2006, 06:07 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Some 800ish 1967 NADA 109 wagons were imported with the Rover 6cyl engine with a Westlake head. A "Euro" 6 was avaialbe as an option for 109's in Europe during the late '60s.
But I agree, LR has not produced a 6cyl that had an MAF.
Old March 9th, 2006, 08:07 AM
Exactly! I knew someone would post about a Series truck with a 6 cyl engine!
Old March 9th, 2006, 10:06 PM
Antonios
No more
Well I won't be the guinea pig for this batch of spare parts. I screwed up the first test of my MAF becasue I didn't have the ECU harness plugged in. I re-tested and got the correct voltage.
Miami, FL
Wanted: Mass Air Flow (MAF) Sensor for 3.9L D90 dbj2003 Wanted 5 May 7th, 2009 02:31 PM
Code 12 - MAF Mass air flow Antonios Defender Technical Discussions 3 August 6th, 2006 06:58 PM
Mass air flow sensor! TwisteD90 Wanted 1 October 20th, 2005 06:50 PM
Air Conditioner Vents on NAS 110 - How to hold direction of flow? COSteve Defender Technical Discussions 5 July 15th, 2004 11:11 AM
