Range Rover Front Brake Caliper Question - Defender Source
Old May 19th, 2006, 07:10 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Can a Range Rover Front Brake Caliper be used on my series coil conversion????? I just noticed that there are 2 brake lines running into the caliper. Can these be setup for a 1 line defender style setup?
Legend in My Own Mind.
Old May 19th, 2006, 09:39 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Those are the calipers I've got. At this point in building your rig up I would pick up some D90 calipers, if only to not have to deal with getting the 2 circuits crossed up.
Name:	new brakes.JPG
Old May 19th, 2006, 10:15 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We use twin line calipers all the time on coil conversion. There is no issue and I can send you the plumbing diagram for them on a coil rig.
However, it is a heck of a lot simpler to use a single input caliper if you have a chance to get some.
Email:
Old May 19th, 2006, 01:58 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, that would be great just in case I can't find a set of single line units. Other then the d-90 what other rovers have the single line caliper?
Old May 20th, 2006, 04:45 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The 110 has them too.
In fact I have a pair of early single line 90 calipers laying in my workshop unused and unloved since converting to the later larger calipers. shipping would probably be prohibitavely expensive though.
Just a thought if you're interested
Mike Hammond
Old May 21st, 2006, 08:04 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, are the calipers for vented disks or solid diske? what do you think shipping would be? What kind of shape are they in?
Old May 21st, 2006, 08:28 PM
robisonservice
John Robison
2008 Supercharged Range Rover
Discoveries have the single line calipers, too
Old May 22nd, 2006, 06:26 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
If I get a pair of disco calipers, can I just bolt a set of solid discs onto the hubs? Will this work?
Old May 24th, 2006, 04:36 PM
mikeslandrover
Mike Hammond
They're in a sort of "I've off-roaded them in best Brisish Mud" shape - used but looked after. They're solid disc type calipers
Calipers are pretty weighty items and thick brown paper and some string probably won't cut the mustard as packaging. Shipping would probably end up quite expensive. I can post a pic of the calipers if you're interested, I wouldn't want that much money for them.
I'll have a look under the wife's Discovery 1 and see what the calipers are like, I thought they were twin line like the classic Range Rover. Goodness knows what I'll find when I do venture under there though! Loading some stuff into the boot resulted in needing to weld in a whole new rear floor - you've never seen rust like it!
As to whether you need solid or vented discs depends on the caliper - if there's a spacer between the two halves of the calipet then they're for a vented disc which is thicker. both types of caliper and disc will bolt onto the axle though!
Mike Hammond
Old May 24th, 2006, 07:47 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Randy,
Call me at the shop tomorrow. I found the shifter you asked me about and I have a set of D90 calipers kicking around under the bench that may be of use to you.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old May 24th, 2006, 08:14 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Cool. Will do Rob. I emailed you back too..
brake, range rover
front caliper brakeline jabber Defender Technical Discussions 5 May 3rd, 2009 11:31 AM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
2000 Range Rover Question mgrgpg Misc. Chit-Chat 7 April 22nd, 2004 12:52 PM
1989 Range Rover Hunter pcarey For Sale - Vehicles 1 November 3rd, 2003 01:12 PM
