Ramblings - Defender Source
Old May 6th, 2004, 12:18 AM
Ramblings
Does anyone know if the ECU and ignition are in any way connected and if so how?
I know the ECU controls fuel, but how does the 14cux (94-95) ignition get controlled?
Also
I am looking for a 3.9 flywheel, a used (worn is perfectly fine with me) V8 R380 or LT77 and either a complete wiring/intake/heads etc or some sort of carb set up.
Ron
Old May 6th, 2004, 12:26 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Off topic, but Ron, is your ecu a 14cu or a 14cux? I thought the 'x' was only for non-North America spec vehicles....
Doug
Old May 6th, 2004, 12:29 AM
I think the ECU turns the ignition relay on, let me check the manual, back in a second.
Old May 6th, 2004, 12:36 AM
After looking at the manual they don't seem to be connected at all. It says the ignition is right off the start switch.
Old May 6th, 2004, 01:40 AM
Sweet. So I can keep the ignition and ditch the efi you think or no
Ron
Old May 6th, 2004, 09:34 AM
Why do you want to ditch the EFI? I'm not 100% that you could do that. Are you going carb?
» Defender Registry
Max
juddy
Honcho
bennett
Add your Defender
