R380 Bearing kit question - Defender Source
Old May 17th, 2016, 08:21 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
This is regarding my disco, so didnt post in the "technical discussion" forum.
Having to replace the bearings on my R380, but understand there are 3-4 different kits depending on the suffix indicated on the S/N located on the gear box. Problem is, I can't find the little metal tag with a serial number anywhere. Any ideas how else I figure out how to order the correct bearing kit?
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old May 17th, 2016, 08:55 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
It shouldn't be on a tag. It's on the flat spot right next to the drain plug on the passenger side.
Old May 17th, 2016, 10:36 PM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
Got it. Suffix J. Thanks Galen.
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
kit, r380
WTB: FTC5200HD (R380 throwout bearing heavy-duty) nathanwind Wanted 4 August 5th, 2014 08:05 AM
R380 Transmission/Gearbox - Only needs a mainshaft bearing fitting overlandbirds For Sale - Parts 0 December 3rd, 2013 09:29 AM
Salisbury Carrier Bearing Question LR Max Series Technical Discussions 0 November 8th, 2013 04:38 PM
Crankshaft Pilot Bearing Question Heath Defender Technical Discussions 15 October 13th, 2009 03:57 PM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
