Questions about engine design - Defender Source
Old January 25th, 2008, 10:44 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I was wondering, other than making it fit in the engine bay, what are the differences btw. say a 90 degree piston alignment vs. 45 etc. How does this change the performance of the motor if at all? For a project I'm trying to design an opposed cylinder motor and the closest thing I have for comparison is a boxer engine but that has cylinder heads and only one crank shaft. I'm trying to see how performance would change with an opposed cylinder motor in a V configuration but I not sure how piston angle alters performance..
Old January 25th, 2008, 07:53 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm confused...if its opposed it can't be a V and if it is a V it can't be opposed. They are mutually exclusive terms as they have been explained to me.
Old January 27th, 2008, 01:06 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I know, I was trying to figure out what would happen if you placed an opposed cylinder arrangement in a V-config for matters if space. I don't think it's been done and I'm sure it not as efficient but I was trying to figure out how less efficient it would be.
Old January 27th, 2008, 01:08 PM
I am so not following this.
Old January 28th, 2008, 08:38 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
What do you mean by opposed cylinder? Normally that means that there is one central crankshaft, and the cylinders are 180degrees from each other. A boxer engine is an opposed cylinder engine.
Or do you mean one of those funky things like a Napier Deltic engine?
-Hans
My oil line fix
My 100k stopped odometer fix
engine
leak at front engine mail seal (due to vibration?) => two questions? MonLand Defender Technical Discussions 23 August 31st, 2006 09:30 AM
about to put in the 4.6, engine questions vesparover Defender Technical Discussions 2 February 27th, 2006 11:10 PM
Should LR Address these Engine Fires Ragland Defender Technical Discussions 49 December 13th, 2005 01:21 PM
