Question for Shop Owners (and others) - Page 2 - Defender Source
Old July 9th, 2009, 02:08 PM
Re: DB's post if you mechanic is dumb enough to blame a 90wt leak on the trans you better find someone else quick.
Old July 9th, 2009, 02:19 PM
specops1526's Avatar
specops1526
Beluga '97 90
It's definitely trans fluid, they cleaned the area and saw the drip after doing some test drives which cost me an additional $15 in gas since their mechanic has a lead foot. Fluid is pink.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 9th, 2009, 02:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
quick question - Who found the issue with your transfer case being jacked to begin with?
If they found the issue and told you to replace it and you said can i give you the part and they had no issue with it I don't how they are not on the hook. No one is expecting them to warranty the transfer case as they didn't supply it but you do expect them to warranty the actual work. To me this means that the truck is found in the condition they got it with the new part.
Now you can't prove it wasn't leaking before hand but to me as they put the new part in they should make sure with the INSTALL it doesn't leak as it is part of a proper install. New seal, old seal doesn't matter. You paid to have the transfer box installed correctly and this means it not leaking at a seal. You did not get what you paid for.
As for the transfer case working who cares as it could be filled with rocks. We are talking install and that is it.
Old July 9th, 2009, 02:24 PM
So in that case, it has nothing to do with the transfer case you provided them with. There are a number of ways they could have damaged that seal during installation of the transfer case. Truth is that they should take on the job at no cost to you. Reality is that you should not let them work on your truck as it will be a losing battle. Live with the leak, fix it yourself, or hire a someone that does not have their head up their ass. $1200 for a used lt230...they need your money to feed their meth habit. Run away...
Old July 9th, 2009, 02:31 PM
specops1526
Beluga '97 90
Shop was the one who diagnosed the problem and told me to replace the tcase along with all the other repairs. I told him I couldn't afford to buy his tcase as it was way too expensive. I asked him if I could find my own and he had no problem with that.
Barry is right, I'm not arguing about the tcase, I'm dissatisfied with the labor/service that I paid for. He should back that up as far as I'm concerned. Sadly, I know he won't.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 9th, 2009, 02:37 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Well it sounds like you have come a long way today already on getting your mind right to resolve the issue. Talking it out first should help you have your arguement honed to a fine point. Being able to discuss the issues at hand knowing where he is coming from should help you resolve it.
It beats the hell out of a shouting match and you may be able to appeal to his logic with the last sentance of the aboive post.
Old July 9th, 2009, 03:05 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
How do you damage a gearbox output seal when plopping on a built up LT230?
That seal is buried behind the seal surface for the LT230 input seal and the t-case has nothing that sticks out to hit it when it goes on.
I guess anything is possible, but, if like most shops, the t-case goes up on a transmission jack and then onto the gearbox it goes up and then onto the shaft and then slides forward.
They would have had to nick the seal by prying the old t-case off with a long pry bar or something.
If the t-case was leaking 90w then that would be easy to damage during an install, but the gearbox output seal????
Email:
Old July 9th, 2009, 03:09 PM
specops1526
Beluga '97 90
His diagnosis is that it's almost definitely the output shaft seal on the transmission. this is an 04 DII if that makes a difference.
anyway, think I'm gonna drive over there in a couple of hours and talk to him about this. I'll let you all know what happens.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 9th, 2009, 03:20 PM
ECR's Avatar
ECR
Well, the output seal is easier to hit in the automatic as it is not protected as well as the 5 speed one, but it is still a super long shot to mess up the gearbox output seal when changing a t-case, especially if they did not remove the tail shaft (no reason to in doing an t-case swap).
I'd check that the gearbox breathers and all are still in tact. If for some reason the breathers got messed up that could cause a gearbox leak. That would be more likely.
It all depends on where you want to stop. One could argue that in the auto you should change the output seal and the output shaft during that job. Others would say just look at it. Others would just rebuild the existing t-case.
If he had changed the output shaft and the output shaft seal would you have looked at the bill and said,"What are all these extras? I didn't want that done!!"
Its a no win situation. Its easy to armchair this stuff, but impossible to know what happened unless you were doing the work.
That isn't fair.
Did you drop off the truck on empty?
If you did they would have to put gas in it to test it.
Email:
Old July 9th, 2009, 03:46 PM
specops1526
Beluga '97 90
Well, he said they checked all the breather tube and there was no clog so that's why he believes it's the output shaft seal...I've come to the realization that it will be a losing battle. I guess you live and learn but I have nothing to lose to talk with him again.
Yeah, I dropped off the car with a 1/4 tank of gas and it was returned to me with that much. Not sure what that charge was about. Total BS if you ask me. Looks like they put about 30 miles on the truck. No way that's $15 in gas. I didn't even question it. Just paid and left pissed off. I won't bring myself to soil their name...
That isn't fair.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 9th, 2009, 04:04 PM
yeah, it does seem like you would have to be trying to mess it up.
I was thinking that they might have put too much weight on the t-box during installation. which would seem ok but if it was an older seal and a bit hard? or nicked it with a pry bar, or got dirt in it, who knows.
also, what if the bearings on the input gear are out of spec? could that cause the tailshaft to float a bit? or what if they did do the seal or did remove the tailshaft and aren't saying so? what if they did something that has caused the tallshaft bolt to come loose or improperly torqued it.?
like you say it is all speculation unless you were there.
Old July 9th, 2009, 04:08 PM
I am to the conclusion that if you want it done right you have to do it yourself. At least if it gets fucked up you can get mad at anyone but yourself.
Old July 9th, 2009, 04:33 PM
My mechanic would smear rightstuff all over the mating surfaces so it will never leak.
Old July 9th, 2009, 04:40 PM
oilburner's Avatar
oilburner
JL
large pile of parts
And then you would curse when you have to pull it off again as the T case is glued to the trans (BTDT, it was waaay more difficult to remove than I thought it would be, right stuff is a power to be reckoned with).
Old July 9th, 2009, 04:56 PM
yah, I never put sealant between the trans and t-box. it won't keep the oil in the casing.
and I have had to pry them apart when others have done so.
i used right stuff on my series gearbox when I had the bellhousing off. then had to do it a year later...it was a right b****
Old July 9th, 2009, 04:57 PM
It does work to seal it up. I personally would not do it, but he does and that is ok by me.
Ron
Old July 9th, 2009, 05:19 PM
so where does the oil go that leaks out into the small void between the two boxes? does it just hang out there until it gets bored or cold and then go back into the gearcase? hopefully someone will be in there with it to tell it which gear case to go back into.
or maybe you just sell or scrap the truck before enough of it leaks out to be noticed
Ron
Old July 9th, 2009, 05:36 PM
It builds up to the point it equalizes pressure and then gets forced back where it came. It goes back to the one that it leaked out of because that is the one with the lowest threshhold for ingress of oil based on its propensity for egress of oil.
Ron
PS this is complete BS on my part, but I have some faith that it does work.
Old July 9th, 2009, 05:56 PM
specops1526
Beluga '97 90
So an update: Went over there and spoke with him. We were both cordial. I stated my case where I felt it wasn't my part that caused the issue but something else when the work was done. He agreed. He said he can't be 100% sure where the leak is coming from until he takes it all apart again, which I agree with. He said he would work with me on cost and do it for bone cheap. Still not sure about that but it is what it is.
He wants to wait a few weeks to see if the leak just "cures itself". He also said that he rarely replaces those as they hardly leak and aren't fully exposed. He said when he mates the tcase to the trans he uses guide dowels just to be safe.
Anyway, so that's my story...not sure what to do next. Not excited to ever go back there. Guess I'll live with the tiny leak for now.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 9th, 2009, 06:19 PM
landrovered
S. Smith
Honestly, I think it came out about as well as you could expect. You had a civil meeting of the minds and found a working solution. Good for you.
