PSA: If you have an 4.4L LR3 or RRS, replace this... - Defender Source
Old May 20th, 2014, 08:57 PM
This is the bleeder hose that goes to the thermostat housing. It is one of the few items on an LR3 or RRS that will leave you stranded very easily. These trucks get towed in all the time from this hose coming apart. A cheap and easy fix would to be to do away with the bleeder all together and just put a double ended hose barb in its place.
I decided to post this since there seem to be a lot of LR3 owners on here, and some may not know of this issue.
Also, I meant for the title to say "a" not "an" but I can't edit it...
Old May 20th, 2014, 09:07 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks! Can you post a pic of the part you recommend installing instead?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 20th, 2014, 09:25 PM
I've never actually installed anything other than the factory part. Something like this in the correct size. I actually had a friend get stranded in Moab because of this and he had to hitch-hike back to town to get a double ended hose barb to fix it.
Old May 20th, 2014, 10:48 PM
draaronr's Avatar
draaronr
Here
LR3
Wait it's a connector to join two hoses?
Old May 20th, 2014, 11:00 PM
Does the factory part just blow apart on it's own or does it take some outside agitation to cause it to break?
Old May 21st, 2014, 12:29 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Appreciate the heads up! Be something to look for.
Old May 21st, 2014, 07:47 AM
They blow up on their own. Usually they crack and seep before the blow apart. If you touch it, it will break.
Old May 21st, 2014, 07:48 AM
Sure is nice to have someone on the front lines
Old May 21st, 2014, 07:52 AM
Any downside to removing that bleeder nozzle? I mean, it can still be bled without that right? If so maybe I'll get a diameter measurement on the hose and figure out where we can get a brass barb that'll fit.
Old May 21st, 2014, 07:58 AM
I've never used that bleeder. I'm not sure how most people filling the cooling systems on these at home, but I use a vacuum filler. You could accomplish the same thing by disconnecting the hose where it connects to the thermostat housing when you are filling it.
Old May 21st, 2014, 09:09 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Jimmy, how long is a new OEM bleeder t good for? I'll make the preemptive replacement as suggested. What was the other part you suggested changing? The thermostat housing/assy as well?
http://www.partsgeek.com/gbproducts/...FaZlOgodq3YANQ
Old May 21st, 2014, 09:25 AM
jafir's Avatar
jafir
Jafir Elkurd
It's cheaper here:
http://landrovermerriamparts.com/par...&siteid=215719
Old May 21st, 2014, 09:45 AM
down_shift's Avatar
down_shift
Russell
Originally Posted by jafir View Post
Thanks for the link. Interesting that the MSRP is listed at $128.59. How can (why does) RN sell it for $148.86?
http://www.roversnorth.com/ProductDe...FS4aOgodn24Ang
For that tee, it looks to be part of item 4 (bypass hose 4.4 L). Not sure how to obtain the LR part number:
http://landrovermerriamparts.com/par...iagram=7116048
Old May 21st, 2014, 09:46 AM
No telling with that bleeder. Kind of like oil cooler lines in my opinion. That thermostat housing does tend to leak, but I wouldn't replace it unless it is leaking. I don't think I've seen one catastrophically fail.
Old May 21st, 2014, 09:49 AM
jafir's Avatar
jafir
Jafir Elkurd
Maybe LR006158 ?
I think roversnorth can get away with charging more than MSRP because a LOT of dealers (not just Land Rover) charge a lot more than MSRP.
Old May 21st, 2014, 09:56 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Because if we sold it for $128 we'd be out of business
Old May 21st, 2014, 10:11 AM
down_shift's Avatar
down_shift
Russell
That was not meant to be a bash on RN, as you guys have found your niche. In fact, I am anxiously waiting for a small box from RN now.
Old May 21st, 2014, 10:15 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I wasn't offended or anything, just looked at the cost and can't understand how Meriam could sell it for that cheap without losing money. Not sure what the pricing structure is for dealers buying parts for the newer vehicles. Thank you for the order
Old May 21st, 2014, 10:18 AM
jafir's Avatar
jafir
Jafir Elkurd
When I worked in a garage (mostly Honda/Acura stuff) sometimes we would get the warehouse "pick ticket" still attached to special order parts. It had dealer cost and msrp on the ticket. It looked like dealer cost was about 50% of msrp for most parts.
I have no similar experience with Land Rover, as we got our Rover parts from worldpac, because we didn't know what we were doing
Old May 21st, 2014, 05:10 PM
Grover's Avatar
Grover
Question
Jimmy,
Should the hoses be crimped before replacing the bleeder with a brass barb to avoid air getting in or coolant getting out? (when engine is cool of course...)
Cheers...
ac, lr3
Cheap lr3/rrs hitch in colorado springs on CL $250 Broncoduecer The Flea Market 0 February 16th, 2014 09:58 AM
RR/RRS/LR3 19" rims & tyres- $400 Paul K For Sale - Parts 2 September 8th, 2013 01:56 PM
LR3 / RRS blower motor heater/AC #JGC500050G nathanwind For Sale - Parts 1 July 19th, 2012 10:59 PM
LR3/LR4/RRS Air Suspension Compressor Blowout discojosh2000 For Sale - Parts 0 December 30th, 2011 09:51 AM
LR3/RR/RRS Trailer Hitch adapter Jamie Deck Wanted 3 December 15th, 2009 09:07 PM
