PSA: If you have an 4.4L LR3 or RRS, replace this... - Page 3 - Defender Source
Old October 5th, 2015, 10:14 AM
Dumb question...why is a tee being used at this junction?
If one port of a tee is closed off, then isn't it just a straight fitting?
For bleeding the cooling system, which doesn't even work, haha.
Old October 5th, 2015, 10:17 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Ordered from Amazon last night, I'll be getting on it later in the week. Thanks again!
"It's not a Jeep"
Old October 5th, 2015, 07:54 PM
Originally Posted by rmuller View Post
Someone posted this Home Depot part in another thread:
SharkBite 3/8 in. Brass PEX Barb Coupling-UC006LFA - The Home Depot
That would be me....best $1.59 fix you can do for your LR3!
Old February 25th, 2016, 10:21 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
About to do this repair today, did anyone confirm if the bleeder valve is necessary or does it work just fine to do the straight brass fitting?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old February 25th, 2016, 10:40 AM
Grover's Avatar
Grover
The brass barb replacement has done well for my LR3 for the last 50,000 miles!
Old February 25th, 2016, 10:47 AM
I'd say don't bother with the "bleeder"...I put the T in, but when I dumped the coolant and did the water pump I didn't even bleed it from there it all bled just fine right through the coolant reservoir. Go with the $1.59 Home Depot barb instead of the $80 brass-T.
Old February 25th, 2016, 10:52 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks guys, will tackle this this evening after I pick up a 3/8 sharkbite fitting at HD.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old February 25th, 2016, 11:06 AM
Grover's Avatar
Grover
I wouldn't go with a shark bite. Go with a standard barb fitting and use clamps.
Old February 25th, 2016, 11:08 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Gotcha thanks
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
morrisdl
Doug
LR3
My T-stat housing cracked right around the same time as the bleeder T. After replacing the t-stat, bleeding the cooling system is nerve racking. i was about to give up twice before all the air bubbles cleared out and the temp returned to normal. Give yourself plenty of time. Overnight settling if possible and keep a keen eye on the temp gauge for the first 50 miles after replacement.
Old February 25th, 2016, 11:47 AM
The one linked earlier is not a Sharkbite style fitting... It was a PEX fitting, just Sharkbite brand.... A Sharkbite style fitting is a different thing that can only work on tubing. Anywho, a PEX connector is not the best either, although it probably works. You want a hose barb coupling.
https://www.fastenal.com/products/details/69988
Old February 25th, 2016, 12:12 PM
JBurt's Avatar
JBurt
Jesse McCoy
I put a tee in and just put a plug in the top "just in case". I think all the parts cost me something like $6.
"It's not a Jeep"
Old February 25th, 2016, 02:00 PM
That is a good point...once the "T" is brittle, the t-stat housing is next on it's heels. Though...didn't hold true in my case as it ended up being my water pump that was actually leaking, but I did the stat housing "while I was in there" anyhow since it was probably on borrowed time:
http://www.defendersource.com/forum/...tml#post716305
Old February 25th, 2016, 02:24 PM
Grover's Avatar
Grover
Have you guys replaced hoses? My 06 lr3 has 130k with original hoses. They look ok...
Old February 25th, 2016, 03:08 PM
morrisdl
Doug
LR3
Im at 120K and look ok too. Im planning on doing hoses, belts and water pump as prevent maintenance next year (if I still own it)...
Old February 25th, 2016, 04:23 PM
Hoses rarely fail on LR3's in my experience.
Old February 25th, 2016, 04:34 PM
Grover's Avatar
Grover
Good to know. Do you ever replace them as PM?
Old February 26th, 2016, 09:24 AM
Nope. I trust original parts more than replacement parts usually.
Old June 17th, 2017, 11:17 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Anyone else find that their falconworks bleeder leaks? I'm going to see if upgrading the hose clamp helps, but mine weeps from around the hose.
Old June 17th, 2017, 11:33 AM
Cap on it needs to be torqued to 35ft-lbs, which is very difficult to do in-situ. Take the T out, put it in a vice, and torque....leak will usually go away. Mine was doing the same thing, but from the cap, and I also had to swap out to smaller hose clamps (I think I used fuel injector clamps if I recall).
ac, lr3
Cheap lr3/rrs hitch in colorado springs on CL $250 Broncoduecer The Flea Market 0 February 16th, 2014 09:58 AM
RR/RRS/LR3 19" rims & tyres- $400 Paul K For Sale - Parts 2 September 8th, 2013 01:56 PM
LR3 / RRS blower motor heater/AC #JGC500050G nathanwind For Sale - Parts 1 July 19th, 2012 10:59 PM
LR3/LR4/RRS Air Suspension Compressor Blowout discojosh2000 For Sale - Parts 0 December 30th, 2011 09:51 AM
LR3/RR/RRS Trailer Hitch adapter Jamie Deck Wanted 3 December 15th, 2009 09:07 PM
