Problems with the safari gard 3 link? - Defender Source
Old February 25th, 2006, 02:35 AM
kevinumali
Kevin Umali
Sorry if this in the wrong place, but I was wondering if anyone here has had problems with the safari gard 3 link suspension set up? In the feb issue of Land Rovers Monthly they talked about how their safari gard set up failed them, I was wondering if this is a common thing, or was cuz of because of the user? The article talked about how the bump stops werent sufficient enough and that the front suspension kept failing. Anyone with this problem?
Old February 25th, 2006, 03:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I think the biggest problem people have with the 3-link is getting one on time Seriously, its a great product for what it is and what it costs.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 25th, 2006, 08:55 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
The LRM article was about a 40k kilometer trip around Africa. For that kind of use I'm not suprised it failed. I've seen them on the trails and they work very well for that kind of thing.
Jimmy Buffett
Old February 26th, 2006, 10:16 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Also, they wee talking about the springs I believe. not the actuall 3-link system.. I run the system and have no problems... I don't run there springs though or and of there shock mount stuff..
Legend in My Own Mind.
Old February 26th, 2006, 03:18 PM
kevinumali
Kevin Umali
hey thanks for your guys' input, its greatly appreciated.
Old February 26th, 2006, 07:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
If you want wheel travel, its the way to go. Also is great when you have a lift cause you can dial in your pinion and castor angle to get it to steer good again. it also protects your tie rod from damage due to its built in protector...
Old March 2nd, 2006, 09:51 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I didn't read the article but I just can't see how a bump stop will cause the 3-link to fail Anyway, the only failure that 3-link had been in early production. The first failure was caused by not having enough separation between the radius arms and the 3rd link, which they fixed. The second failure happened b/c SG used a stock x-member and welded the 3rd link mounts to, under sever braking the x-member will buckle and cause the axle to rotate, now SG sells a HD x-member. Other than those two there wasn't any failures.
World traveler
Old March 2nd, 2006, 10:15 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Grahams truck doesn't have a three link.. The failure was the set up.. The shock mounts failed because the front springs/bumpstops allowed the axle to travel more than the shock. The solution will be taller front shock mounts..
Keith
Keith
Big, Red and ... aaa Red..
problems
Safari Gard National Press Release SafariGard The Vendors Loft 18 June 19th, 2009 09:37 AM
safari gard stuff GeoParth Wanted 2 November 21st, 2005 02:15 PM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 11:41 AM
Interesting one for Sale on Ebay--the Safari Gard OCD90 Misc. Chit-Chat 8 April 13th, 2004 12:32 PM
Greg and Brandi Jevne chrisvonc Defender Owners 0 February 22nd, 2004 09:38 PM
» Defender Registry
130
kellymoe
Watson
80sailor
Add your Defender
