Problem With New Mantec - Defender Source
Old July 23rd, 2016, 11:56 PM
RBBailey
RBBailey
1965 IIa
First ---- This is not me complaining. I'm pretty excited about getting the tire carrier. I'm posting just to see what experience you've all had with this type of thing, what worked best.
I found a problem with the new Mantec tire carrier I got today from Rovers North. Nothing big, but it means I can't install till it is fixed. One of the stud bolts on the plate that mounts to the rear door is just slightly out of alignment enough that the piston won't fit on the plate. If I had bought this used, I'd drill out a bit of the piston mounting hole to make it fit, and I'd never think of it again. But....
So, I don't want to send this back ...partly because I already dismantled the boxes... and partly because it's something like $60 for shipping. So I'm hoping they will only make me send the one plate back.
So do I talk to Rovers North or do I call Mantec? I'm planning on calling Rovers North on Monday if no other wisdom is posted here.
Project:
1965 IIa SWB
Old July 24th, 2016, 06:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You're in a tough spot because RN might have the same feeling as you and not want to do the repairs themselves. They might be obligated to send it to their supplier.
Old July 24th, 2016, 06:54 AM
roverguy's Avatar
roverguy
Robert
1995 RRC
I would be annoyed, but I would drill it out and forget about it. I wouldn't be able to wait to get it on anyways!
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old July 24th, 2016, 07:11 AM
Chris B
72 + D1 drivetrain =?
Let's see a photo of the issue.
It's odd that after making these things for decades that a problem would appear.
Old July 24th, 2016, 08:45 AM
Just call RN. Their problem, not yours. I'm sure they will send you a replacement. If you ask, they will probably even send a call tag to return the first one. You can use the box the second one came in to make the return.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 24th, 2016, 09:16 AM
Chris B
But if the second unit was part of the same batch. It's likely to have the same issue.
Old July 24th, 2016, 10:36 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
You could ask them to check the fit before they send it. If it's a manufacturing issues with the batch, Mantec should make it good.
Old July 24th, 2016, 10:41 AM
RBBailey
RBBailey
1965 IIa
Not sure how else to show what is going on. It's just that those two studs are too close together for the piston to slip on. Tried it every which way I could.
Project:
1965 IIa SWB
Old July 24th, 2016, 11:56 AM
RBBailey
RBBailey
1965 IIa
This is how some do it. If this doesn't happen, I'll probably just drill it myself.
Project:
1965 IIa SWB
mantec
new Mantec snorkel GaryBaxter For Sale - Parts 4 November 1st, 2013 02:52 PM
New Mantec Window Guards - $150 shipped smob For Sale - Parts 2 October 19th, 2013 01:13 PM
Mantec Adapter Plate for new style rear door bjf For Sale - Parts 6 September 29th, 2010 11:03 PM
Mantec Raised Air Intake Snorkle Top (NEW) roverboy For Sale - Parts 6 December 20th, 2006 08:19 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 02:07 AM
