Pressure washer recomendations - Defender Source
Old October 3rd, 2016, 12:55 PM
We use a pressure washer a lot. Need 2600psi or more. The higher the pressure the less run time on the engine and pump.
My karcher had an unloader valve fail, put a new one in, and now it pulses so time for replacement.
Sams Club and Home Depot and Lowes all carry Simpson brand and they seem to have good reviews.
Old October 3rd, 2016, 01:00 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I have had a honda for years. I think it was a lowe's purchase. I am very happy with it.
Or find one of these: http://www.govliquidation.com/auctio...D#auction_tabs
Old October 3rd, 2016, 01:18 PM
FlyersFan76
1987 110 Convertible
I have a Karcher and like it. I bought from a dealer. I probably do not use mine anywhere as much as you but it starts easy enough.
The only thing that I do not like is the washer bottle as I am not even sure how to use it.
2011 Range Rover Sport
1987 Land Rover 110 Cabriolet
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
[QUOTE=tjfslaughter;772058]I have had a honda for years. I think it was a lowe's purchase. I am very happy with it.
Or find one of these: Simpson Industrial Cleaning System Mdl King Brute portable pressure washer Sn 03130094, rip cord pulls, no nozzle, sligh - Government Liquidation[/QUOTE
I'll go for that one, 3000 psi industrial and heats water up 100 degree's over ambient. Mark just retired and lives down the street from that location. Y'all dont bid against me.
Old October 5th, 2016, 12:14 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I have a Deere that is 3100 or 3300psi, obviously I abuse it and it's been dead reliable.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old October 5th, 2016, 11:40 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Get hot water if you can, it's worth it, you use a lot less water, make a lot less mess and less chemicals. (Karcher hot water machine here).
JL
Old October 5th, 2016, 12:46 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Doug - that GOV surplus machine is a monster - but should be good for you cleaning old British farm trucks on a commercial scale. I may have to stop by your farm on the way home from MAR next year......
Firemanshort
1980 Stage One 109
Sterling, VA
Old October 5th, 2016, 04:02 PM
tjfslaughter
thomas
Burbon
Did you Lick it?
Old October 5th, 2016, 04:16 PM
Yep I own it. With buyers premium I'm in it for $300. I could have bought a decent brand new machine for that $.
Typical roverphile type purchase. Buy some old rusty broken ass item for more that you could buy a new version of something else for, because of its perceived potential.
That said its still a currently offered model so all parts are available and a quick google search shows its a $2900-$3k machine. Hopefully this tid bit from our Uncles trash can doesn't take a ton of time and money to get operational.
Upside is I have to go to Portsmouth so meeting Mark and Robert the Davis @ the Bier Garden is an automatic as is our usual. http://www.biergarden.com/
------ Follow up post added October 5th, 2016 04:24 PM ------
JL it says it heats the water to 100 degree's above input temp. Around here thats 57 or so degree's so not really that hot. But 157 degree water @ 3000 psi should remove everything but waxoyl- I hope.
SIMPSON KB3028 - KING BRUTE 3000 PSI
HOT WATER PRESSURE WASHER
KEY FEATURES
Briggs and Stratton Intek 1100 Series OHV Gas Engine
12 Volt Burner System with Automotive Alternator
Burners run on KEROSENE or #2 DIESEL FUEL. Clean Burning, Steel Wrapped Vertical Combustion Chamber is fuel efficient. The extra large steel fuel tank provides all day cleaning without need to refill.
High quality coil heats water temperature 100 higher than incoming water source while the high temperature limiting switch ensures water remains safe for operation. Clean burning and fuel efficient.
Heavy Gauge Steel, Welded Construction
3/8" x 50' Steel Braid Hot Water Hose is Non-Marring and Abrasion Resistant
Down Stream Injection System
5 Quick Connect Nozzles - 0, 15, 25, 40 & Soap
DESCRIPTION
The King Brute is designed for long days filled with the toughest cleaning assignments. This hot water pressure washer does not compromise on power or performance! The four wheel chassis make it a snap to maneuver around the job-site. The robust Briggs & Stratton engine powers the industrial triplex pump via a direct drive system, delivering streamline power and performance. These features make it the King of the Brute series of high pressure washers.
SPECIFICATIONS
Water Pressure 3000 PSI
Flow Rate 2.8 GPM
Motor Briggs and Stratton Intek 1100 Series Motor
Pump Type Industrial Triplex Pump
Wheels Four 13" Premium Pneumatic Tires
Pump/Hose Quick
Connectors Yes
Hose 5/16" x 50' Steel Braid Hot Water Hose with Quick Connectors
Hose/Gun Quick
Connectors Yes
Wand Type Quick Connect Spray Wand
Engine Orientation Horizontal
Frame Heavy Gauge, Welded Construction
Frame Tube Style 1-1/4" Square Steel Tube
Frame Handle Style 1-1/4" Square Steel Tube
Accessory Storage N/A
Unit Length (in) 40.5"
Unit Width (in) 26"
Unit Height (in) 44.75"
Old October 5th, 2016, 05:13 PM
oilburner's Avatar
oilburner
JL
large pile of parts
That's almost the same specs as mine, only mine puts out less pressure. Mine is rated to 90C but it seldom ever gets there, usually I can't get much more than 70-75C out of it (160F or so). I have really cold well water so that doesn't help. If you can get it working well it should be super useful. I had a big 8hp unit with way more GPM but I got rid of it once i got the Karcher, the heat makes all the difference.
JL
Old October 5th, 2016, 07:34 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Damn DOUG I have this FS
Old October 5th, 2016, 07:38 PM
Holy crap, I forgot you had the Binford 9000000 power washer. Does it remove paint from fenders and siding from houses?
Old October 5th, 2016, 09:10 PM
mother of god what is that ? The stack on that is bigger than my forklift.
Old October 5th, 2016, 10:00 PM
tjfslaughter
thomas
Burbon
Looks like an ISIS water boarding device.
Old October 6th, 2016, 08:57 AM
josh-man's Avatar
josh-man
joshua
Originally Posted by tjfslaughter View Post
Looks like an ISIS water boarding device. Sent from my iPhone using Tapatalk
Cannot confirm nor deny lol how do you think we got OBL? 30,000 psi obviously!
Old October 6th, 2016, 09:33 AM
josh-man's Avatar
josh-man
joshua
Well commercial power washer that also does aggregate washing. A wet sand blast, if you will. 30 or 40hp Perkins Diesel. The thing is amazing. Made my money back on it after the first year of doing weekend jobs at Bath Iron Works. Going up for sale soon, no time.
Old October 6th, 2016, 10:26 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
How much? (Just what I need.)
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old October 6th, 2016, 10:27 AM
too funny, the Massey Ferguson forklift has a 3 cyl perkins diesel. Machine looks like a beast.
Old October 6th, 2016, 10:39 AM
josh-man's Avatar
josh-man
joshua
Originally Posted by GuamPilot View Post
How much? (Just what I need.) Mike & Carrie
Gonna list it for 30-but probably would take 22-25 ish
80k new
Old October 6th, 2016, 10:57 AM
speedpin's Avatar
speedpin
Looking ;)
wwwwooowww
~ Semper Fidelis ~
Taveling to England - Looking for Recomendations Stmpede Misc. Chit-Chat 28 August 5th, 2013 12:41 AM
Slider recomendations? pacificwildfire Defender Technical Discussions 101 June 1st, 2011 01:02 PM
Spray Paint Recomendations everglades Defender Technical Discussions 9 December 19th, 2007 03:13 PM
Any new battery recomendations? mountaintek Defender Technical Discussions 20 November 21st, 2007 02:07 AM
NAS 110 Suspension Recomendations NAS 110 Defender Technical Discussions 9 January 11th, 2006 10:12 AM
