Power Window install - Defender Source
Old September 24th, 2005, 05:11 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I just got done installing power windows in my 130. $100 for the motors off Ebay. They went in pretty easy. I will do a write up when I take some pictures. They work great
Old September 24th, 2005, 09:25 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Kevin,
That rules... I'd be interested in pics/instructions...
I saw a D90 wagon going on eBay last week, and the guy had power windows but didn't show any info... not even a pic of the 'controls' inside the truck.
Bravo.
Nicholas
Old September 24th, 2005, 09:32 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Originally Posted by norros
Kevin,
Bravo.
Nicholas
I am at work and wont be home till morning. I will try and get some pics of the motor in the truck.
Here are a few pics of the motor Ii bought off Ebay.
Old October 4th, 2005, 06:16 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Here are a few pics of the install. I removed all previous window mechanisms and trashed them. I utilize the plate on the door to help mount the new motor and the cut to size some of the hardware that came with the new power window units. Wiring was easy. I just tucked it up under the dash and wired it to a unused hot wire behind the cigarette lighter that only gets power when the ignition is on. My door panels are shot so I will be looking for new ones soon. The red tube tucks behind the panel and does not interfere with it's operation. The controls on the drivers door operate both windows. With this setup I cannot roll the windows down all the way. Both winndows stick up about 2 inches, that is the only bad thing about the install so far.
ID:	3968   Click image for larger version
Old October 4th, 2005, 06:32 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
very nice, good work there!
Old October 6th, 2005, 11:13 AM
mgrgpg
Mark
1989 D110
Looks good - what causes the windows not to go down all the way?...Is the track on the motors you bought too short?
Mark
Old October 6th, 2005, 11:18 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Mark
The motor takes up too much space in the door. I had to cut the track down to fit in the door frame. Another type of motor may work better but for the money I spent, less than $100 for two motors I can put up with the inconvenience.
window
Power Lock install Overlander Defender Technical Discussions 17 January 14th, 2010 08:15 AM
D2 Window regulator install? JohnsD90 Defender Technical Discussions 5 December 15th, 2009 02:22 PM
Window Guards- To install or Not NashvilleRover Defender Technical Discussions 11 February 3rd, 2009 11:13 AM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
