Possible mechanical fan option... - Defender Source
Old May 28th, 2005, 09:35 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
In my excessive digging, found an interesting part
Flex-a-lite #851 and #852. They are adapters to convert clutch-fan systems to a direct drive mechanical fan (I.E. No clutch) They are both the same part in 30mm x 1.5 threads, one is standard threading, the other is reverse. They are priced at $43 at Summit, plus you would need a fan and most likely a spacer too. But it might be a good option for uprating the airflow through the radiator.
Now, anybody know the threading on the nose of the water pump? Or do I have to take a chance?
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 28th, 2005, 09:49 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I'll check tomorrow!
Old May 28th, 2005, 10:36 PM
Hans's Avatar
Hans
Hans Haase
Cool, thanks. If I can get a solid "yes/no" on the threading, I will be more than willing to give this option a go and report back. If the adapter fits, then I'll order it and start trying different fan options and such.
-Hans
My oil line fix
Old May 29th, 2005, 12:05 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I was gonna volunteer if Peter can't get it to you (but I'm out of town right now). I just happen to have a water pump on my front porch...I'm sure I can fix it, ha ha ha, but at least I'm gonna try.
"It's not a Jeep"
Old May 30th, 2005, 04:29 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
The threads are 1.5 mm I am not sure of the 30mm measurement.
Old May 30th, 2005, 05:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I would not do this if this is what I think it is. No fan clutch robs HP and puts serious stress on both the engine and the fan. Really not a good idea.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 30th, 2005, 06:42 PM
Hans's Avatar
Hans
Hans Haase
Well, if the adapter fits, you don't necessarily need to run a non-clutched fan. If it's really M30x1.5 threads (which is looking more to be the case if it's definitely x1.5) then it's a standard pilot. I'm also planning on trying to source some direct-fit clutches as well for those who want them. Hayden has a really comprehensive listing in their catalog, there's GOT to be a cheaper way to do it. It might mean replacing both the clutch AND the fan, but the goal is cheaper and better even in that case.
That being said, the Buick/Rover V8's were run for 20 something years with direct fans until the mid 1980's. As long as you use a fan rated for a high enough RPM range, you'll be fine. I honestly wouldn't mind the 2-3hp loss in this case, since it means one less part to fail which can be almost impossible to diagnose. Plus, it won't be running at a reduced speed like a fan-clutch, and will have a lot bigger blade area. It's a compromise, but which one you choose depends on what you use the truck for.
It's all about having options. But what I would REALLY like to find is a spec sheet for the factory fan-clutch that shows all the critical measurements. That would make things a lot easier.
-Hans
My oil line fix
Old May 30th, 2005, 11:38 PM
Hans's Avatar
Hans
Hans Haase
Ok, got the deal on this one. Bad for me and other V-belt guys, good for the serpentine belt folks I think.
The V-belt V8's appear to have an M24x1.5 theading on the water pump nose. The only other cars with that threading are BMW's, which are even pricier. Well, damn... that sucks. But flex-a-lite does do some custom work, so I might ask them about doing an M24x1.5 adapter. Either that, or a couple machinists I know might be into it. If anybody wants in, let me know.
BUT. For the serpentine belt crowd, it appears you guys ARE the M30x1.5 threads (reversed rotation). There are piles of viscous and thermal clutches out there for you guys, as well as upgraded fans... etc... etc... etc... Seems it was the standard threading for Ford and Mopar.
-Hans
My oil line fix
Old October 18th, 2009, 09:57 AM
Cmikefly
William Challancin
97 NAS D90
Hi,
I was just reading over this old post and was wondering if anyone has confirmed that that the 30 x 1.5 fits on a 97 and what the result was.
thanks
William Challancin
Al Ain, United Arab Emirates
1997 NAS D90
2005 110 TD5
Old October 19th, 2009, 01:33 AM
Hans's Avatar
Hans
Hans Haase
Unfortunately I never dug further into this one, and ended up going with an electrical flexi-lite 210 setup in mine. Since I don't have access to a '97 truck to do the measurements on, there isn't much I can do to push any further.
-Hans
My oil line fix
fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
RUDD 4x4 GRIP Chains & Kenlowe Fan kit for Sale Barnett Childress For Sale - Parts 0 May 18th, 2005 07:24 PM
Fan replacement davedeojay Defender Technical Discussions 10 March 23rd, 2005 02:00 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
