POE top with Safety Devices Rack - Defender Source
Old November 11th, 2007, 11:31 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I don't know how many people are running a Safety Device rack with a POE top, but I though I would give you my thoughts on it.
I recently bought the rack figuring the rear ladder would fit fine and the rack would go on top like it should, but my suspicions about the front support bars was true. I knew that the front rollcage that goes over the window was a one off piece custom to the POE tops. My initial thoughts were that the rollcage supports would be too tight to the top to allow the feet to clamp on...I was right! But there was also another thing I didn't factor in. Both front support bars are the same. Same height, and length, yet the rollcage bit slopes upward as it goes from the front to back. It goes up about an inch so the second support would not fit in there.
I figured I would leave it out for now, and take out that little 1 inch block between the bar and feet of the support and get some modified feet made up that would be more like a hinged C clamp to go around the bar and hook into the support bar.
In all I think it looks sweet on the truck and will help out with the bikes and snowboards! Also I just banded myself from every parking garage known to man.
ID:	11008   Click image for larger version
ID:	11010   Click image for larger version
Old November 12th, 2007, 01:03 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Too bad its so much trouble. What lift do you have on there? I like the way your truck sits, looks good!
Old November 12th, 2007, 05:16 AM
are those 35" please do tell more about your truck
Old November 12th, 2007, 11:17 AM
ini88's Avatar
ini88
Daniel Marcello
Thanks a lot Andrew!
Suspension: 3 inch Rovertym springs. Land Rover top and bottom rubber isolators. EE spring retainers on all 4 corners. Rockware rear shock mounts. Rover Hybrids front external mounts. 14 inch Bilstein 7100 SB w/ remote res all around. Rovertym rear links. working on getting a 3-link in....but you know how Safari Gard is.
Wheels: 315/75 BF Goodrich Mud Terrains on LR Boost alloys.
it rides great. I think the i need to re-valve the Bilsteins to 275/78 instead of 360/80. other than that it handles great on the road and feels good so far off road. the front sits a tad higher than the rear because the springs are set for a large bumper and winch. once i have a winch in there i bet it will even out nicely.
Old November 12th, 2007, 12:02 PM
Troys
Troy Smith
1995 D90 SW
Roof Rack
Daniel
I believe if your get the correct "FEET" that you will find that you can in fact use both factory roof rack rails with no issues. The factory feet are built up and serve the purpose of the 1" square tube shown in your photo. The rear support does run fairly close to the hardtop. On my SW it prohibits opening the sunroof all the way. I took a factory roof rack off of a POE a few years back and then re-installed it. Used all the same factory pieces my personal truck has. If I recall correctly, the factory roof rack kit came with round spacers that were to be used with a ST. I may have that backwards?
Troy
Old November 12th, 2007, 02:57 PM
ini88's Avatar
ini88
Daniel Marcello
Troy, my problem isn't having the second bar touch the top, but the actual feet touch the top when i try to clamp them onto the bar. my feet come apart and I have a top and bottom piece both with two brackets that extrude out to hold the bolts in. the extruding parts are about 3/4 of an inch. and the space between the collcage and top is about 1/2 inch to 1/4 an inch. its super tight.
I checked out Rover Connections and the feet they have look different then the feet i have. His look like they would work a lot better seeing as there is only one bolt that is on the outside of the rollcage.
http://roverconnection.com/Def%20Acc...ari_Rack_A.jpg
http://roverconnection.com/Def%20Acc...ari_Rack_B.jpg
http://roverconnection.com/Def%20Acc...ari_Rack_C.jpg
http://roverconnection.com/Def%20Acc...ari_Rack_D.jpg
Old November 12th, 2007, 03:02 PM
Troys
Troy Smith
1995 D90 SW
Daniel;
The feet from Rover Connections apear to be the factory feet that should work. Remember to not overtighten those feet as they are cast aluminum and will crack if torque to much. I think those will be your answer.
Troy
Old November 12th, 2007, 04:11 PM
ini88's Avatar
ini88
Daniel Marcello
So if those are factory feet I wonder what I have then? The rack came off a 97 limited, so they might be different? I will take some pics later. Also, I think the feet i have are steel.
Old November 12th, 2007, 04:46 PM
Daniel - from studying your pix closely, I can tell you have non-stock feet. They appear to have been fabricated, probably at some point after the orginal feet broke. The stock feet fit nicely and work well as long as you (as Troy said) overtighten or otherwise abuse them. If I were you, I would fit four stock feet, then use stacked washers to create the spacing that you require. The stock soft top cage does require the 1" spacers between the crossbars and the rack, but it appears you will only use those at the front, something less will be needed on the rearward crossbar.
Old November 12th, 2007, 04:55 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
He's also missing the 2nd cross support
Chris von C
[/size]
Old November 12th, 2007, 05:21 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I think he has it but b/c of the angle of the bar he could only attach one to the rack.
BTW, a cleaner solution than a bunch of washers would be a short piece of tube or a pre-made spacer from McMaster.
Old November 12th, 2007, 06:13 PM
ini88's Avatar
ini88
Daniel Marcello
I have the second support bar, but have it out. I was trying to figure out how to put it in there, because of the upward slanted roll cage bit over the window. I will take pics of the brackets tonight. Im kind of pissed that they aren't original as the guy that sold it to me said everything was original and in pristine condition.
Old November 13th, 2007, 10:36 AM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
The A-hoop on a POE is actually the same one from when it was a soft top (the rest of the cage was removed at port), that's why it tilts up. The NAS Wagon cage actually has a taller A hoop with connecting bars that run parrallel to the top of the door. See the pics below and look at the amount of space between the horizontal bars and the door on a soft top and on a wagon. There are supposed to be spacers between the support bars and roof basket for a soft top as the parrallel bars sit lower, and no spacers on the wagon as the bars are higher (again, because the A-hoop is taller). I would suppose in you case you could use spacers on the front support and none on the rear support. Hope that helps.
Will H.
(thanks to Copley for use of their pictures)
Here's a POE with Safety devices rack that just ran on ebay. I believe this supports my argument, spacers in front, none in 2nd support (see pics).
http://cgi.ebay.com/ebaymotors/1994-...QQcmdZViewItem
ID:	11026   Click image for larger version
ID:	11028   Click image for larger version
Old November 13th, 2007, 11:34 AM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Here is my ST converted to SW with a ST A-hoop. I added a spacer to the front cross rail where it attaches to the rack to takeup the space due to the tilt.
Gary
Old November 13th, 2007, 12:06 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks Will and Gary! So it looks like my main problem is not space or room, but the fact that my feet that clamp onto the roll cage are not genuine. the genuine feet will fit around the cage fine and then after that I just need to add spacer to get it to the correct level.
now excuse me, while i hassle the guy that sold me the rack to buy me the original feet!
Old February 7th, 2008, 04:40 AM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
I realize this is an old post, but Daniel, Will is right on the money. The POE front hoop is 1" shorter up front and slopes up to compensate for the added height of the hardtop. Here's a pic of a green factory hardtop. Notice no slope above the window:
By now you probably already bought the crossbar mounts from roverconnection.com, which will make no difference. The slope will still be there.
Post an update to see how it looks.
Javier
Old February 7th, 2008, 08:59 AM
ini88's Avatar
ini88
Daniel Marcello
Javier, I did buy the roverconnection crossbar mounts and to my surprise it worked out great. The other mounts I had when i bought the rack had a 1 inch piece welded to it. I don't know why this was done, but with that added lift in the front, the original style roverconnection mounts fit perfectly in there. I will try to post up some photos of the rack/mounts this week
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 7th, 2008, 10:14 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
Hey Daniel,
That is one fine, kick ass looking wingtop air intake scoop!
Old February 7th, 2008, 02:56 PM
ini88's Avatar
ini88
Daniel Marcello
I know! this great guy Len (I don't know if you know him) made it!! haha.
you should see the interior too! he made me an awesome GPS mount that sits where the ash tray is
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 7th, 2008, 02:59 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Funny what you said about being banned from parking garages. I recently installed a Thule MOAB basket to my '07 Wrangler's hard top. I let my wife drive it to work a couple of weeks ago and remembered just in time to call her and stop her from flying into the parking garage at her office and tearing the roof off of my Jeep
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
ac, rack, safety devices
ISO: ANY PARTS for NAS safety devices roof rack NASD90 Wanted 3 February 28th, 2005 01:22 PM
FS/T: DII Safety Devices Roof Rack craines51 For Sale - Parts 5 December 12th, 2004 07:55 AM
brownchurch vs safety devices roof rack? NASD90 Defender Technical Discussions 10 December 9th, 2004 10:39 AM
roof rack alternatives - safety devices paulb Misc. Chit-Chat 3 December 2nd, 2004 09:35 PM
WTB: Safety Devices roof rack 110 artm Wanted 0 June 2nd, 2004 11:19 PM
