Pneumatic Brake Bleeder - Defender Source
Old January 12th, 2015, 11:49 PM
Anybody use one? I'm sick of the pressurized pot and am thinking about something like this.
Neiko 31119A Vacuum Brake Bleeder
Old January 13th, 2015, 06:09 AM
roverguy's Avatar
roverguy
Robert
1995 RRC
I have one, works well to get you started, but I always finish up the old fashioned way.
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old January 13th, 2015, 11:38 AM
Nobody else has a working one person method suggestion?
Old January 13th, 2015, 11:53 AM
Originally Posted by javelinadave View Post
I'm sick of the pressurized pot....
What exactly do you mean by that?
Personally I use a Motive Power Bleeder, http://motiveproducts.3dcartstores.c...der_p_115.html Works great. Easy to use.
Old January 13th, 2015, 12:08 PM
Thumbs up
That is what I use. I hate having to fit the cap onto the MC, pull the chain around things, tighten things up and hope I didn't knock an electrical fitting loose or accidentally disconnect a vacuum line or something. Pulling the fluid thru looks to be soooo much easier than the multi step approach of the Motive bleeder. It would also be nice to be able to do the clutch MC by myself.
Old January 13th, 2015, 12:18 PM
Chain? It should just screw right on. Takes seconds.
Vacuum bleeders never work as well and I would never do it on a clutch.
Old January 13th, 2015, 12:25 PM
I must have a universal kit. It has a cheesy chain that holds the flange onto the top of the MC.
Old January 13th, 2015, 12:30 PM
Get the European adapter: http://motiveproducts.3dcartstores.c...ter_p_114.html Makes brake fluid flushes a relaxing experience, IMO.
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Yes, that's cheesy.
I have a vacuum bleeder and I've used a Motive pressure bleeder(not the cheesy one). The Motive wins hands down. Its one step with the Motive.
With the vacuum bleeder I always had to finish by manually bleeding(push, open, close, release).
* Vacuum bleeder for sale! :D
Old January 13th, 2015, 01:00 PM
Thanks, I'll order one and give it a try.
Old January 13th, 2015, 03:52 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I also have the motive products unit with the euro cap...have used it for over ten years on my BMWs and Rovers... Only way to go
Ryan
84 110SW County LHD
07 L322 Vogue
Old January 13th, 2015, 10:59 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I'd get the Motive "black label" euro adapter, bit more $ but better made and has a swivel so you aren't coiling the hose as you screw the cap on. I also put a thin coating of silicone or rubber grease on the gasket to get a better seal.
I've never enjoy using vacuum bleeders; I find it hard to distinguish between air in the system and leaking around the bleeder threads.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old January 13th, 2015, 11:08 PM
UKmtrsp
Chip
95 RR Classic
What #4 said...motive
bleed, brake
Pneumatic gear oil pump? Abrooks Defender Technical Discussions 17 October 19th, 2009 10:29 AM
How many bleeder valves? sflash868 Defender Technical Discussions 16 October 10th, 2008 04:16 PM
Motive Power Bleeder Antonios For Sale - Parts 2 November 18th, 2007 05:24 PM
power bleeder psi D90user Defender Technical Discussions 1 October 5th, 2006 11:29 PM
power bleeder thewap Defender Technical Discussions 1 August 4th, 2006 07:03 PM
