Please share your thoughts on D90 History - Defender Source
Old November 27th, 2007, 12:28 PM
matthewwcarey's Avatar
matthewwcarey
Matthew Carey
95 D90 SW349
Looking for some advice on a 1995 Wagon I am interested on buying, itís a car which spent most of its life in MA. Here are a few excerpts from the dealers warrantee service history:
25,434 miles: Replaced R/H ball joint on drag link, due to squirrely feeling while driving
Rebuilt L/H joint in drag/drop arm, due to squirrely feeling while driving
Replaced gear box, fit new gears, due to excessive whine noise above 30mph.
Replace worn bolt on pan head rod bearing, due to excessive movement.
Replace F/R diff seals, due to leaks.
Replace F/R Stub axle seals, due to leaks.
Replace front crank seal, due to leaks.
Replaced rear end T box washer, due to leaks.
Replaced broken exhaust at manifold.
27,063 miles: Replaced front diff, due to hard shifting and excessive whine noise.
Replaced stub axle seals, due to leaks
Replaced connectors on rear stop lights due to corrosion.
Repaired LF Door jam, RF Door jam, rear body panel, RS & LS waist rail, LR & RR corner/ seams, Replaced RF & LF door hinges, Replaced and painted rear cargo door, due to corrosion.
28,248 miles: Replaced drive shaft, due to vibration between 55-70mph.
55,041 miles: Repaired LS & RS waist rail, LR & RR corner, windshield area, Replaced and painted both front doors, and cargo door, due to severe corrosion.
The car has 79,000 miles on it now and looks great; please share your thoughts on the dealerís repairs, particularly the corrosion repairs, and what I should look for before proceeding.
Thanks for your help Matthew
Old November 27th, 2007, 01:01 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
any pictures??
Old November 27th, 2007, 01:28 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That is no surprise for a truck used as a daily driver here. We salt the crap out of the roads for no apparent reason.
I would be concerned about the bottom of the bulkhead and frame, depending on the price being asked for this truck.
Old November 27th, 2007, 02:00 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I'd think either two things... one, it had a lot of problems or two, the original owner complained about every little thing and got warranty to take care of it..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old November 27th, 2007, 02:59 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Sounds like the service department is making up for a slow sales quarter. The owner might also be of the sort who prompted LR to switch the Mud Terrains for All Terrains.
Many of the issues with Defenders were attributable to owners who expected the refinement of a Range Rover.
"Uhh...I think they all leak like that."
Old November 27th, 2007, 05:17 PM
If the truck lived on the coast or an island, I would be extremely concerned about rust in the frame and bulkhead as well as the front two doors. Replacing fenders due to corrosion is a big red flag.
You need to look at it carefully. Mechanically, that is par for the course if not a little better than average.
90, d90, ht
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
