Personalized license plate - Page 2 - Defender Source
Old June 10th, 2010, 09:34 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Mines the one on the right
http://solaros1.smugmug.com/Land-Rov...3_t3349-X3.jpg
Old June 10th, 2010, 09:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I toyed around with 4x4xfar but never went there. Still like it, still might...
Old June 10th, 2010, 10:48 AM
At this point I personally recommend skipping them, but before I got the D90 I ran "NO D90" on my jeep, and now have "GOT D90" inspired by the Got Milk? campaign but no-one gets it.
Old June 10th, 2010, 11:23 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by dave_lucas View Post
Fe2O3
Are you implying that your Defender is a Rust Bucket?
I use to run 'JEEPETR' way way back when I got it. Unfortunately the Jeep crowd didn't seem to take the joke too well, so I went back to a regular tag to avoid the hassle on the trail..
~Scott T.
'95 D-90 ST - AA Yellow
Old June 10th, 2010, 03:17 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Nope, just thought it would be a cool plate, I have the standard green and white plate issued by the state.
Thought about using my UK reg plate number but I did not want to pay 100+ per year for a fancy plate
I have been amazed at how little rust it has on it. I have yet to break a bolt and most of the bolts still have a silver or gold color to them.
Considering it lived in the UK 25 years it is in great shape.
Old June 10th, 2010, 03:40 PM
Went with DFND 110 on mine...everthing else with "Defender" or variation of was already taken in VA.
Old June 10th, 2010, 03:43 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Good thing about Minnesota is that the vanity plate is a one-time charge.
Old June 10th, 2010, 03:45 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Hey Chris! The guy I bought my '95 from back in '99 had that plate! It looked pretty cool 4X4XFAR. He took the plate with him as a momento and his next vehicle was a VW bug so I can't imagine he transfered the plate (can't remeber if you could still do that back then). It may just be available!
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old June 10th, 2010, 03:54 PM
Overland90's Avatar
Overland90
95/D90 #169; Aston Martin
mine is "DPARTNG"...I thought about "DPRTING" but I may have been mistaken for "INS" here in SoCal...too close to AZ Border!
Old June 10th, 2010, 05:08 PM
rovertrader's Avatar
rovertrader
Dale
had LIVLIF but now considering OLDGIMP for me and the Rover...
Old June 10th, 2010, 07:49 PM
Awesome picture Dale!
Old June 10th, 2010, 11:54 PM
rovertrader
Dale
thank you sir- great trip in Co a few years ago
Old June 11th, 2010, 11:53 AM
stu454
Stu
2007 LR3
Just recalled that the same guy with FINS2L had UPKEEP on a CJ-7 that he used to have.
Stu
Old June 11th, 2010, 01:34 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Originally Posted by JackW View Post
Did you make that hitch? Sort of looks like a modded series plate. Any more info?
1970 SIIA 88, Sold
Old June 11th, 2010, 02:34 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
4xfar
I have "4XFAR" and most people don't get it.
Old June 11th, 2010, 06:55 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I built the hitch from a piece of 6" channel, a piece of 2" angle and a receiver tube from Northern. Its similar to the one Rovers North sells but it only cost me about $18 to make it...
Old June 14th, 2010, 03:57 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Here is a closeup of my hitch
Old June 14th, 2010, 04:30 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I like it. Thanks for the pic. Keen on making another?
1970 SIIA 88, Sold
Old June 14th, 2010, 09:41 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Not really - all you need are three pieces of metal, a Bosch jigsaw, a heavy duty hand drill and someone who can weld them together for you - think of your pride of accomplishment when you build one your self!
Rovers being what they are - the hole pattern has enough small variations where you almost have to custom fit the hitch to the rear crossmember so its really best to make your own.
The three pieces you need are:
8" length of 6" channel - about 1/4" thick
14" length of 1-1/2" x 1-1/2" x 1/8" angle
Receiver hitch tube from Northern - around $14-$18
Notch the lower edge of the channel for the receiver tube (tight fit is best), bevel cut the upper legs of the channel. Cut a notch in the RH vertical leg for the hitch pin to clear.
Notch the vertical leg of the 14" angle to fit over the tube. The vertical leg goes toward the rear and the uncut leg goes across the top of the receiver tube facing forward. Test fit the pieces and mark the hole pattern in the rear crossmember on the channel and also where the two holes that are in the bottom of the cross member will line up with the horizontal leg of the angle iron. Drill undersize pilot holes (8 [laces) as well as the two holes for attaching the chain. I can't remember if I had to shorten teh receiver tube by an inch or so to clear the gas tank - maybe but it wasn't much.
Tack weld the receiver tube in the channel so the forward edge of 5/8 hole for the hitch pin is about 1/2" forward of the web of the channel. Slide the notch in the 14" angle down over the top of the receiver tube behind (forward side) of the channel with the horizontal leg facing forward and tack in place. After some test fitting weld the heck out of all the joints (front and back) and step the holes up to finish size, bolt it up and tow away.
Old December 27th, 2011, 03:21 PM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
I was poking around the MVA site today and found that "D90" was now available in Md, so I grabbed it.
license plate
License Plate Help Part 2 excanuk Misc. Chit-Chat 6 January 11th, 2013 04:49 PM
NEEDNORD license plate rovertrader Misc. Chit-Chat 3 March 15th, 2010 01:28 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Personalized License Plate Jon_Winningham Misc. Chit-Chat 38 May 12th, 2007 11:57 PM
License plate Mike Hippert Misc. Chit-Chat 27 September 16th, 2004 04:07 PM
