Perfect Suspension - Defender Source
Old May 29th, 2007, 02:19 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Perfect Suspension
After five years of ownership, I think I've finally put together the perfect suspension for my driving style and vehicle (Defender 110):
1. OME 766 front and 754 rear for a three inch lift
2. Oversized Koni HT Raid shocks all around, HD shock towers in front, cones in back
3. RoverTym castor-correcting front radius arms
4. Scorpion HD read sway bar with quick disconnects and reinforced mounts
The truck is really tight (on the bumpy side which is fine), turns perfectly, tracks well on the freeway, and articulates adequately with the bar disconnected.
Runs at speed with precision over double-track and graded roads, and with the reinforced sway bar mounts, the bar can remain connected for all but technical situations.
Just FYI. Cheers!
Doug W.
Old May 29th, 2007, 04:07 PM
that's good information for planning! next logical question: What's your driving style?
Old May 29th, 2007, 10:11 PM
Doug's Avatar
Doug
Doug Walker
Aggressive. My impossible goal has been to blend a bit of sports car handling into a big heavy truck that can also attack difficult trails and obstacles. I think I've gone about as far as I can without giving up one for the other.
(Note that tire pressure becomes important at well. I am running 32 front, 38 rear and still have a bit of oversteer.)
Old May 29th, 2007, 11:57 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Doug, you did not give us your tire size!
Old May 30th, 2007, 12:18 AM
Doug's Avatar
Doug
Doug Walker
255/85/16, 33"
Old May 30th, 2007, 10:19 AM
ok, let's see some pics please. I need to visualize this.
Old May 30th, 2007, 07:15 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Just FYI. Cheers!
Doug W.
Doug,
Could you post pics of the HD sway bar and the disconnects.
--Benjamin Franklin
Old May 30th, 2007, 07:45 PM
Doug's Avatar
Doug
Doug Walker
I'll need to take some pics. Can do this weekend.
Old May 30th, 2007, 07:51 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
F the pics, let's see the videos of the races!
Thanks again for the info
"It's not a Jeep"
Old June 1st, 2007, 02:18 PM
Doug's Avatar
Doug
Doug Walker
Here's pics. (The tube running through the rear sway bar mount is a fuel return line for a spare tank.)
ID:	9541   Click image for larger version
ID:	9543   Click image for larger version
ID:	9545   Click image for larger version
Old June 1st, 2007, 02:47 PM
Very nice Doug. When are you going to write up you tech post on your rear disc brake conversion (on my short list of near term todo's)?
I would like to see a side shot of your rig in daylight!
Old June 4th, 2007, 02:38 AM
Doug's Avatar
Doug
Doug Walker
Here's a pic.
I'm afraid most of my recent wrenching has been done with my checkbook. Eddie Bostock at West Coast Rovers did the brake conversion. I believe he used the Zeus kits from the UK.
DW
Old September 2nd, 2008, 08:14 PM
d90-110
gustaf kupetz
93 D-110
perfect suspension
Nice ideas about suspension, I'd have to add one thing though. Take a Classic (93-95) front axle housing, two sway bar mounts that you've scalped out of the same classic and lastly a front sway bar. This makes for one nice, yet stable ride.
I'd mention it's cheap on the wallet as well, but once you have your front end apart you might be tempted to updated your CVs, Axles, ARB & 24 spline diff out of that... same classic. But anybody buying a older nas 110 should rebuild it anyway, why not update it as well. Now if you felt like using two shocks per side, with that classic axle, your that much better off.
Hands down the best mod I've done.
-Gustaf
Gustaf Kupetz
arlFOUR.com
93 D110
94 D90
94 LWB
Old September 2nd, 2008, 09:13 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
As someone who has ridden in Doug's truck both on the highway and on the dirt I can attest to the fact that this is about as good as it gets. If I had the $$$ I would do the same to my truck.
Old September 2nd, 2008, 11:03 PM
d90-110
gustaf kupetz
93 D-110
Perfect suspension
Yep, didn't get into springs and what not as I've got Koni's & OME's on my range, I can attest they work fine. just thought I'd add to it. that's all.
-Gustaf
Gustaf Kupetz
arlFOUR.com
93 D110
94 D90
94 LWB
Front Suspension Buckon37s Misc. Chit-Chat 17 November 27th, 2006 01:02 AM
Rear Suspension Buckon37s For Sale - Parts 5 October 10th, 2005 10:58 AM
OME suspension id kolvedic Defender Technical Discussions 1 August 15th, 2005 01:46 PM
range rover air suspension issues ember Defender Technical Discussions 0 February 18th, 2005 01:56 AM
bilst. suspension, tires/wheels, others SeaRover For Sale - Parts 9 May 26th, 2004 12:26 AM
