Pen Drive Data Recovery - Defender Source
Old April 24th, 2013, 08:33 AM
The Dro
Dro
1988 Ninety
It's been ages since I do any work on electronics.
My Pen Drive is not working and need to know if anyone here can help me.
The LED light is on all the time.
Do you know which resistors I need to short? Which one is the fuse?
ID:	70646   Click image for larger version
Old April 24th, 2013, 09:10 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Use a hammer to crack it open to get your data out.
Semper Fi!
Old April 24th, 2013, 09:22 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I don't understand the problem...you have an led light that stays on all of the time but the drive works...right?
Old April 24th, 2013, 09:34 AM
The Dro
Dro
1988 Ninety
When I connect the Pen Drive, the LED turns on. But the PC doesn't recognize it.
Old April 24th, 2013, 09:36 AM
Rugbier's Avatar
Rugbier
Gustavo
Doooood.... get a usb drive
NO SIGNATURE
Old April 24th, 2013, 09:39 AM
The Dro
Dro
1988 Ninety
I need the data on this one BAD.
Old April 24th, 2013, 09:43 AM
Wolf Fabrication
Sterling Archer
'08 D3
Porn?
Semper Fi!
Old April 24th, 2013, 09:50 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Have you rebooted PC? Did you Scan the PC for New Hardware? Any drivers downloaded for the pen drive?
Have you tried any recovery software? ie http://www.wondershare.com/disk-util...-recovery.html
Have you tried it on another PC or laptop?
If you need help I can Teamview your PC and try to figure out what is going on.
John C.
Old April 24th, 2013, 10:01 AM
The Dro
Dro
1988 Ninety
Originally Posted by Wolf Fabrication View Post
Porn?
Rover Porn and tax stuff.
Have you rebooted PC? Yes
Did you Scan the PC for New Hardware? Yes
Any drivers downloaded for the pen drive? No
Have you tried any recovery software? ie http://www.wondershare.com/disk-util...-recovery.html I tried it and get "No Drive Found"
Have you tried it on another PC or laptop? Yes. At work and the 2 at home.
If you need help I can Teamview your PC and try to figure out what is going on.[/QUOTE]I'd have to be at home. I cannot do it at work.
------ Follow up post added April 24th, 2013 10:03 AM ------
I'm guessing I have to do something like this:
Old April 24th, 2013, 10:07 AM
87 D110 (Ruby)
Why is that it is always Pedro with these issues??? Dooooood go paint your truck!
Old April 24th, 2013, 10:14 AM
Bill Larson
Bill Larson
Yeah kind of hard to support when you're not on site...go find a local pc guy that has a glimmer of intelligence in his eye...future planning for multiple backups is necessary...but you're an engineer, I'm preaching to the quire...
Old April 24th, 2013, 10:22 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
More like a 6'6" wilmer valderrama
Old April 24th, 2013, 10:25 AM
The Dro
Dro
1988 Ninety
If I spend the time, I'll figure it out... This is not quantum physics.
I was looking to see if someone that does this shit for a living could help me faster.
What did I do to you to call me this.
Doooood....
Ive always though of you as Lazlo from real genius. This completely shatters my mental image of you.
-Jeff
You guys are killing me here... I deal with 13.8kV and 8,000 A equipment. Not 5VDC and 1ĶA
Old April 24th, 2013, 10:29 AM
It sounds like a hardware problem with this usb stick, especially given the pictures, but can you tell us if this got damaged in some way?
If it were me, I'd try another computer, and then under linux which gives better diagnostics about what is happening when you plug in the device. It could be filesystem corruption, which in that case is also easier to handle under linux - you image the drive to a file and then work on it like you would on any other drive or drive image. It is likely small enough to send to someone else to help you with as well.
Originally Posted by pendy
I'm here for the D's
Old April 24th, 2013, 10:33 AM
The Dro
Dro
1988 Ninety
Yes, it is a hardware issue. These things have a fuse and I think that it's bad. Without the schematics it's impossible to figure it out.
The pen drive started giving me "Write Protection" a few days ago.
This one does not have the switch to turn on-off the Write Protection.
Now, once is plugged in the red LED stays on all the time.
Windows will not recognize it.
Old April 24th, 2013, 10:42 AM
It sounds like the disk was dying and you ignored it
You need linux. Email me if you want help with it.
Old April 24th, 2013, 10:45 AM
Can't you just use the tax files you have printed out, or use the PDFs you have saved elsewhere?
The Dro
Dro
1988 Ninety
I know. I was an anti-Ms for a LONG time. I miss Linux.
We'll talk later.
:thankx:
Old April 24th, 2013, 10:48 AM
F the taxes. It's the rover porn man!
Old April 24th, 2013, 10:49 AM
The Dro
Dro
1988 Ninety
Exactly...
I have the taxes in hard copy.
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
oil leak(s) coming from my drive train michael15 Defender Technical Discussions 24 September 15th, 2005 10:28 AM
Drive line problems HELP D90user Defender Technical Discussions 4 February 17th, 2005 10:19 PM
Rear recovery point souza Defender Technical Discussions 33 September 22nd, 2004 11:41 AM
