Part number for 300tdi D90 steering wheel? - Defender Source
Old February 19th, 2004, 10:04 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Anyone have the original part number?
Old February 19th, 2004, 10:56 AM
tbmcneill
Guest
Posts: n/a
i've looked specifically, but its not any different than ours is it? there is an earlier 'thinner' model, but every other 'real' Tdi I've seen had the same wheel as ours, I believe. (but, i haven't seen from-the-factory Tdi's).
T
Old February 19th, 2004, 11:01 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I thought the tdi one had the green LR emblem and was thinner, without the head pillow ours has....
Old February 19th, 2004, 11:07 AM
tbmcneill
Guest
Posts: n/a
now that you mention it, I have seen that in LRO, LRM, or something .... seems like that was in one of the newer models (2000+). again, i'm going off vague memory. that might be one for George at RDS.
T
Old February 19th, 2004, 11:39 AM
I know for a fact I saw some BRAND NEW D-90 steering wheels on th RDS site a whlie back.
Troy is that the remnants of a Rover in your avatar?
Old February 19th, 2004, 11:48 AM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
Dave
the part number is either NTC8847 or ANR3231 both are the ones that you are looking for with the green oval in the center.
I checked with George a while back on one of these and they are huge money. They are the same material as the stock NAS wheel.
Old May 24th, 2004, 04:45 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Martin or anyone else. Any idea if these can be retrofitted to our steering column? Just curious....
Old May 24th, 2004, 04:52 PM
I dont see why not, but I have never looked into it
Old June 18th, 2004, 09:06 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
FYI for anyone thinking of doing this. The 300 tdi steering wheel will not fit the NAS V8 steering column. The diameter of the wheel mount is larger, by about 1/4".
Hope this tidbit helps...
Old June 18th, 2004, 09:34 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Is this the one you guys are talking about ?
I was thinking of fitting it, glad to know it won't fit though...
Nicholas
Old June 18th, 2004, 09:43 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yup, that's the one. I like the design much better than the NAS steering wheel because it lacks the "head pillow". But whatever...
Old June 19th, 2004, 08:24 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
You can use a TD5 steering wheel on our NAS models I think. You may want to check, but I think they switched back to the old steering column like we have for the leather wrapped wheels.
Old June 22nd, 2004, 10:28 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Chris, you are right. The TD5 steering wheel is the same design as the NAS wheel, same column but it's leather wrapped.
On a side note. If your doing a conversion and using your NAS V8 main wiring harness. I discovered last night you can swap out the warning lamp indicator from the NAS with that of the 300tdi. They are a direct fit. Only difference is the tdi version has the glow plug light in place of the check engine light since we have no ECU. I know it may be small and insignificant, but it made me happy...
Name:	105_0532 (Small).JPG
ID:	870   Click image for larger version
Name:	105_0527 (Small).JPG
300tdi, 90, d90, part, tdi, wheel
Defender Steering wheel center shawnpalmer Wanted 17 October 17th, 2006 08:06 PM
Part number for front marker lenses? Hans Misc. Chit-Chat 4 December 3rd, 2005 11:00 PM
Part Number for AC Idler Pully mgrgpg Defender Technical Discussions 2 August 4th, 2005 10:07 AM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Steering wheel removal? howellm70 Defender Technical Discussions 5 February 5th, 2004 06:14 PM
