Painting an early 110 - Defender Source
Old November 20th, 2013, 08:15 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I'm going to be painting my 110 with a coworker who has a paint booth setup in his garage. My plan is to have the 110 keswick green because I love the color. Problem is I also really like the original galvanized trim look. It's an 85 w/ galvanized trim and cappings in really good condition on the tub and on all four doors. It's currently trident green and after removing the County decals I think the keswick would look w/ the trim remaining galvanized. I've never seen any pictures of a keswick green 110 or 90 with unpainted galvanized trim and cappings; only with painted cappings and no trim on the doors.
Any ideas if it will look ok or have any pics with a vehicle painted as such? I'm fairly excited. He's painted his FJ40 and it looks really really nice. My wife spied it in the neighborhood he lives in and she normally doesn't talk about old trucks ever and does her best to ignore them.
You little rebel, I like you.
Old November 20th, 2013, 09:10 PM
What color did he do? I don't know much about auto painting, but I think metallic colors are more difficult to get to look good.
Old November 20th, 2013, 09:19 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
He did a tan color. Keswick isn't metallic.
Old November 20th, 2013, 09:40 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Keswick with galvy cappings would look bitchin'. Go for it.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old November 20th, 2013, 10:10 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I dig the look of the galvy cappings and I think it would look really good with that color combo.
Unknown Author
716-898-8153
Old November 20th, 2013, 11:53 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Keswick is a great color. FYI: not all colors are available in every paint system. When I repainted my 110, PPG could not do it in Concept and I did not want a base/clear.
1970 SIIA 88, Sold
Old November 21st, 2013, 10:03 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
X2
Matt, the galvie cappings will look awesome with that color. Do it!
Old April 26th, 2014, 09:38 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Alright. I have installed my Allisport intercooler and radiator. Installed my rear OME springs so the truck doesn't sag with the spare on the rear door. Time to paint prep. I am not planning on removing panels to paint... yes I know I'm not doing it "properly". That's not my goal. The paint is faded and has extreme patina. It's 29 years old. This is meant to refresh it and change it to the most ballin' ass color ever.
What have people done for random spots like the rubber strips that go between the roof and the sides? There's like 2mm or 3mm visible? Obviously I can tape things like cappings etc. and then do the same with rubber seals on windshields and push the tape under it too but that part has me completely miffed. Any ideas? Or just paint it and not worry?
Or should I deal with the ass pain of unbolting the entire interior roll cage, removing the headliner and all the panels and door and roof? I mean. I just want it painted. I can always do it again correctly like 12 years from now when I am not in the military anymore and have free time.
Old April 26th, 2014, 10:04 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Take it apart…
If you have a skilled helper you should be able to strip out the interior, pull the glass, roof, upper sides, doors, wings, floors, grille, and bonnet off in a weekend.
You can leave the seatbox, tub, t-posts, and bulkhead in place - drill the rivets and pull off the galvanized pieces you want to keep unpainted. Mask the mechanicals (engine, trans, frame, steering wheel, etc…) and go to town with the paint.
let it cure a couple weeks while you clean up the galvanized bits and tend to any mechanical items that need touched while you have easy access - and then start putting it back together with new foam seals and rubber bits.
Not quite a full restoration - but a million times better than just masking and spraying. It's easily 4 times the down time of a quick fully assembled respray but if you intend to keep or sell the car it is the right way to do it short of a full disassembly.
Old April 26th, 2014, 10:13 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Originally Posted by Mybluett View Post
Take it apart…
:'( That sounds so miserable.
Old April 26th, 2014, 10:18 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
It can be. Still a lot of work… But when it all matches, inside and outside, and you need to pull a panel or adjust something later on without cracking painted-over seams you'll be glad you did.
The answer to your question on how to shortcut the roof gasket is:
Unbolt the roof and lift up enough to remove the rubber. Mask and set on spacers in place. Paint and when cured put the gaskets back in and bolt the roof down.
Old April 26th, 2014, 10:20 PM
cbfritz_03
Carmen
none
It's really not that bad
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Aren't you like a Lt. Col. by now Greenie?
You can't be seen rollin' in a 110 with a cheapo respray!
I think Mybluett is onto something, it will look mo better in the long run...
Rent my
Old April 26th, 2014, 10:26 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
If I do his work around then I might as well take it all apart. Sadly I'm still a lowly Captain but I am crushing flight hours like a boss. It's just a lot of down time and work. Is it bad to spray it shitty styles and then live with it for a while until I have more time? Is that too ghetto?
Old April 26th, 2014, 11:43 PM
It is a ton of work to fix a bad paint job.
Old April 27th, 2014, 12:17 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
How much more than what the paint job or lack of paint job is now? The reality is I'd be happy brush painting it without taking it apart to spray.
Old April 27th, 2014, 12:26 AM
cbfritz_03
Carmen
none
Lol.. oh come on.. it's really not that bad to take it apart. It's like a Lego truck .. are you really going to be happy with brush stokes on your truck?
Old April 27th, 2014, 12:31 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I was with my 90 I DD'd for 3.5 years in the UK. I think of Rovers the way I think of dogs. I'd be happy with any of them and would gladly adopt every single one that needs a home. There has only been one Rover that I ever wanted to get rid of.
If you do it right the brush works alright and doesn't leave terrible lines or strokes.
Old April 27th, 2014, 12:37 AM
cbfritz_03
Carmen
none
I understand that...I feel the same way. Would that be to load up with a lot of paint and use a soft brush? And what was the Rover and why?
Old April 27th, 2014, 01:21 AM
chris snell
Chris Snell
87 Ex-MOD 110
I'm telling you, it's really not that bad. These trucks are not hard to take apart and even easier to put back together. Nothing looks worse than a shitty respray en place. Honestly, I love the patina of the early Defenders. Jason Rose's brown truck is gorgeous and has so much character. I wouldn't ever paint it but if I had to, it would be a proper job.
2013 LR4
110, paint
Early 110 Front Seats 1of40 Wanted 0 February 19th, 2013 03:41 PM
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
defender 110 for sale ember For Sale - Vehicles 3 June 17th, 2004 12:28 AM
