P&P Exocage Value - Defender Source
Old June 4th, 2015, 11:15 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
P&P Exocage Value
So I've got this P&P full external roll cage for a 110 CSW. It was installed on a parts vehicle I bought that I don't think it was ever actually driven. It had tie-ins for an internal B-hoop and I had P&P make one to match the cage.
I'm thinking of going a different direction on my build and starting to think I may want just an external front hoop and half internal cage.
So I guess my question is: what's a used (but unused) cage worth? It's admittedly scuffed up from being moved around in storage, the b-hoop is unpainted and the front cross-brace is unpainted as well(was missing when I bought it so I had one made by P&P). Some of the hardware is starting to show a bit of rust from when it sat outside. It is complete and I even have the original manual that was in the truck still.
Oh I should mention I had the front struts (tie to the bulkhead) galvanized and I had the tie-ins to the rear cross-member freshly gold zinc plated.
Still deciding what to do, but if I can figure out roughly what it's worth it will help me decide how I want to move forward.
ID:	122214   Click image for larger version
Old June 4th, 2015, 11:25 AM
You'll probably want to provide model number (unless there's only one). I'm curious what that looks like from the side - is that a light bar set back from the windshield (does the portion above the B pillar curve forward)?
Old June 4th, 2015, 11:27 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It's a really good looking cage, a buddy of mine on here has one. I'm not sure it lost much value being installed and removed, probably still worth something to a good amount of people
Old June 4th, 2015, 11:28 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
No number I can find. The manual jast says "full external cage for 110sw".
Yes there is a light bar mounts on the top of the front hoop and the b hoop curves forward to mount to the seatbelt bracket. I'll look for a side pick. It's not on a truck right now.
Old June 4th, 2015, 11:39 AM
A new cage is more than 3k after shipping. I'd start by asking for offers between 1.5 and 2k.
Old June 4th, 2015, 11:51 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Not quite a full side shot, this is the closest I have.
I guess I should start looking at what the new one I want will cost me and see if it makes sense.
Does anyone make a cage that has an external front hoop that looks like a NAS 90 front hoop buy ties into an internal cage through the sides of the roof. I see the Safety Devices ones, but they look like they mount through the top of the roof.
Old June 4th, 2015, 12:06 PM
First, my opinion is that you should use the cage. These things are NOT cheap.
Second, have you tried contacting P&P to get a price?
As you can imagine, asking on D-90 for "how much something is worth" will typically result in very low numbers.
Old June 4th, 2015, 12:10 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Yes I'm waiting to hear back both what one like this would cost new and what one in the style I'm after would cost.
I know I should use it, it's well made and I have it. I'm sure I'll loose on value if I do sell it but I just don't know if I'll ever be totally happy with it aesthetically. Just not a big exocage fan .
I'm also toying with the idea of a pop up roof so this would be out... and would probably need something custom built.
Old June 4th, 2015, 12:20 PM
phoenix37's Avatar
phoenix37
john
why didnt you tell me you had this when i bought your doors?!
Old June 4th, 2015, 12:22 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Well I'm still toying with what to do.... Plus not sure the RURR driver from Canada would have agreed!
Old June 4th, 2015, 12:26 PM
phoenix37's Avatar
phoenix37
john
just messing with you..
Old June 4th, 2015, 01:34 PM
What will you do about all those holes in the body? Once you go exo-cage, it's hard to go back...
Old June 4th, 2015, 01:47 PM
Internal holes are easier. A cage is on my to do list but Brewie and Clay's tire carrier comes first
Old June 4th, 2015, 01:56 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
The cage is going on my new 110. It has no holes yet! So nows the time to decide. All those fresh new body panels I cringe to drill them.....
Old June 4th, 2015, 02:24 PM
oilburner's Avatar
oilburner
JL
large pile of parts
If you change your mind about using it, we should talk...
Edit: I'm still undecided on what I want to do for mine, either an external A bar hoop with internal B and C, or full external. External is good for 4 wheeling in our area, but I wanted to be able to run a double cab roof, which would look a little strange with an external cage.
If I go full external, I would need to stretch the rear section due to the longer body, and this cage being "used" would be a good candidate for being modified a bit.
JL
Old June 4th, 2015, 02:27 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Oh I'm pretty sure it's not going on I'll let you know......
Old June 4th, 2015, 02:45 PM
rovertrader's Avatar
rovertrader
Dale
What about a Tithonus (would need shortened 3") cage?
Or a NAS90 A hoop with internal B from a wagon? You could add the internal rear section for the 110.
Old June 4th, 2015, 02:50 PM
oilburner's Avatar
oilburner
JL
large pile of parts
This is what it would look like:
------ Follow up post added June 4th, 2015 02:54 PM ------
NAS A hoop with custom B and C pillar hoops was my original plan...
Ideally I would like to be able to pull the double cab roof during the summer and run with no top. The NAS A hoop would be fairly easy to remove and reinstall. I don't want a full internal cage, would like some protection from branches around the windscreen...
Hijack over...
JL
Old June 4th, 2015, 02:58 PM
For some reason, the styling of the P&P cage make the Rover look like it's wearing a bicycle helmet.
Old June 4th, 2015, 03:03 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Yea I like that Idea of the external NAS A bar and the internal B and C. To be honest I would be tempted to take a crack at it myself if I could find someone in town with a more sophisticated bender than the Hossfeld I have access to.
------ Follow up post added June 4th, 2015 03:07 PM ------
I'm undecided about the full length internal cage. I'm most concerned about protecting the 1st and second row passengers. I mean how much more can the rear section do for occupants? I suppose the diagonal bracing helps prevent racking.
cage
130 expedition exocage build Brewie212 Smaller Projects 70 June 8th, 2015 05:06 PM
Performance & Protection Exocage (B Hoop) Wilboro Defender Technical Discussions 4 February 27th, 2014 09:43 AM
Who has that 110 with an Exocage Korongo Misc. Chit-Chat 15 February 8th, 2014 09:04 PM
Mounting Hannibal rack to NAS110 Exocage Overlander Defender Technical Discussions 2 September 8th, 2011 11:31 PM
what exocage/ roofrack is this? d90dang Defender Technical Discussions 3 February 22nd, 2011 09:35 PM
