P&P Exocage Value - Page 2 - Defender Source
Old June 4th, 2015, 03:08 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Originally Posted by JimC View Post
For some reason, the styling of the P&P cage make the Rover look like it's wearing a bicycle helmet.
I agree. There is something about the A hoop transition that just catches your eye.
------ Follow up post added June 4th, 2015 03:12 PM ------
This is interesting:
JL
Old June 4th, 2015, 03:17 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Interesting indeed!
Old June 4th, 2015, 03:23 PM
With respect to a NAS style front cage tied to an internal one, I've wondered if it would be possible to take the NAS style front part (still available from SD) and tie it into a b-pillar (110 style) internal hoop using the brackets as fitted to a NAS 90 station wagon. I know that's a pretty terrible description, but the normal NAS 110 B-pillar cage attaches through the top of the roof and SD offers "over the top" front sections, but these look weird to me. I think the only mod necessary would be cutting of the brackets on top of the B-pillar portion and installing ones that connected to the roof panel at the sides. Again, I know the description sucks but I think all the parts exist to do this.
Old June 4th, 2015, 03:43 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I am doing essentially the same thing you are describing on my 90 so that I can remove the hard top more easily. I have a Brewie made internal rear cage that I am tying to the a hoop with one set of bars for the soft top and another set with the bracket to bolt to the roof when the hard top is on. I have more or less finished the side bars to be used with the soft top but need to order another tube clamp to make the hard top set.
The only draw back is that with no top the side bars stick out like horns because the rear cage is made to fit under the aluminum hard top.
I got one of those Exmore mesh tops that attach with bungies so I had more flexibility in fitting the soft top.
Old June 4th, 2015, 03:51 PM
This is what it would look like:
------ Follow up post added June 4th, 2015 02:54 PM ------
Not quite, but close. That one has 4 cross-bars, while the one Willboro has only has 3.
Old June 4th, 2015, 04:13 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
P&P Exocage Value
Something like this would be ideal and worth pursuing. Looks like there might be some demand!
------ Follow up post added June 4th, 2015 04:14 PM ------
It almost looks like that front cross bar goes over the cage in this pic. Kind of like there is something else up there.
Mine certainly doesn't have that.
------ Follow up post added June 4th, 2015 04:16 PM ------
Pics?
Old June 4th, 2015, 04:24 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I wonder what the NAS 90 SW style A hoop would cost, shipped, from safety devices. I think we could get two. The rest would be pretty easy to build. Ideally I would want an external A hoop that ties into the internal B hoop through the roof, then the rest of the cage internal. That would be much more useful to me than an external cage.
All I would need is this:
http://www.safetydevices.com/expedit...agon/270/1774/
The rest would be custom.
JL
Old June 4th, 2015, 04:35 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
We should look into it!
Old June 5th, 2015, 05:58 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Originally Posted by Wilboro View Post
Something like this would be ideal and worth pursuing. Looks like there might be some demand! ------ Follow up post added June 4th, 2015 04:14 PM ------ It almost looks like that front cross bar goes over the cage in this pic. Kind of like there is something else up there. Mine certainly doesn't have that. ------ Follow up post added June 4th, 2015 04:16 PM ------ Pics?
I guess I only took a pic from the good side! Looking from the front or the side it doesn't stick out so bad. This is the bar that would be used for the soft top. The hard top bar will look the same but have one of the square "thru the roof" brackets welded on.
I will add some more pics when I get home.
Old June 5th, 2015, 08:20 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Just got some pictures from P&P. They make this sort of cage already. Aesthetically looks pretty nice. You can get either the full length inside or have it terminate at the c hoop.Click image for larger version
ID:	122343Click image for larger version
ID:	122344Click image for larger version
ID:	122345Click image for larger version
ID:	122346Click image for larger version
ID:	122347Click image for larger version
Old June 5th, 2015, 03:18 PM
BlackField's Avatar
BlackField
Oscar
D110
Interesting indeed!
That's what I wanted when I originally bought my SD cage. That's an awesome set up.
Old June 12th, 2015, 07:43 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Here are a couple of pics of the bars for the soft top. I haven't gotten the hard top bars made yet but they will be the same but with a plate to bolt to the hard top.
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Originally Posted by wilboro View Post
something like this would be ideal and worth pursuing. Looks like there might be some demand! ------ follow up post added june 4th, 2015 04:14 pm ------ it almost looks like that front cross bar goes over the cage in this pic. Kind of like there is something else up there. Mine certainly doesn't have that. ------ follow up post added june 4th, 2015 04:16 pm ------ pics?
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Old June 12th, 2015, 07:44 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Old June 12th, 2015, 08:37 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Attachment 122816
Pretty neat. This will be interesting to check out when it's all done!
Old June 12th, 2015, 09:32 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
With the hard top on it should look just like an NAS. And if all goes as planned I should just be able to remove the screws from the plate on the hard top, undo the tubing clamp and pull the bar out so the hard top is free to lift off.
cage
130 expedition exocage build Brewie212 Smaller Projects 70 June 8th, 2015 05:06 PM
Performance & Protection Exocage (B Hoop) Wilboro Defender Technical Discussions 4 February 27th, 2014 09:43 AM
Who has that 110 with an Exocage Korongo Misc. Chit-Chat 15 February 8th, 2014 09:04 PM
Mounting Hannibal rack to NAS110 Exocage Overlander Defender Technical Discussions 2 September 8th, 2011 11:31 PM
what exocage/ roofrack is this? d90dang Defender Technical Discussions 3 February 22nd, 2011 09:35 PM
