Oztent and zero propane camping - Defender Source
Old December 3rd, 2012, 10:56 AM
winn442's Avatar
winn442
Winn Bearden
I like to comfortable when camping. Over the years, I've acquired so much stuff, and got used to using it all. It used to not be a problem because when I usally go camping, I towed a trail truck with either a pickup or Excursion, so I had plenty of room for all the creature comforts. Now that I'm trying to take it all in a 90, I run out of room real quick, even with a roof rack. So I revamped my whole setup.
First of all, I hate propane. It's expensive and bulky. So the first thing I did was hit Ebay. I already had one Whisperlite, so I bought two more, and bought three stands. I attached two of the stands together with a small hinge. So now I can cook with a griddle over the two Whisperlites, and the whole setup takes up only a quarter of the space a Coleman stove took up.
Next I took my Zodi Hot Water Shower and ditched the propane burner. I had already replaced the cheap battery operated with a small "on demand" RV pump. I took an aluminum grease pot from walmart, turned it upside down and cut three "L" shaped notches in it to hook onto the third Whisperlite. Drilled holes in the top and coiled copper line inside. Now I have a hot water shower kit that takes up half the size of the Zodi and runs on white gas!
Can't stand to be cold, I've always used a Catalytic propane heater in the tent. I was about to give in and keep that piece of equipment when I found a Sears (made by Coleman) catalytic tent heater from the 70's that ran on White gas! It had never been used! Haven't used it in a tent yet, but I ran it in a bathroom with the door shut and it worked fine, no smell at all!
Next, I needed to organize the inside of the 90. No one ever rode in the back, so I removed the one seat I had. I always keep a trunk in the back for recovery gear and a bugout bag, and usually stack similar trunks in when I go camping. Since I wanted to keep most of my camping gear permanently in the truck, I searched for better storage solutions. I stumbled across these boxes when I was in Office Depot, they fit on the wheel wells perfectly! Two in front of the Engel, and two in front of the toolbox. All the cooking equipment and shower, along with towels fit in those boxes. Then I got two clothes hanging rods and put then across the top of the back between the alpine windows. There I store two chairs, air mattress (rolled up inside a chair bag), and a pop up shower stall. A small folding table sits between the rear A/C and trunk.
So now I have everything in the truck at all times except sleeping bags, clothes, and tent. I could have gone with a small tent and put it up against the roof with the chairs, but I like a big tent. So I bit the bullet and ordered an RV-5. (merry Christmas to me!) It should be the only thing that has to reside on the roof rack.
ID:	62060   Click image for larger version
ID:	62068   Click image for larger version
Name:	storage right.jpg
ID:	62070   Click image for larger version
Winn Bearden
Old December 3rd, 2012, 11:06 AM
I like those containers, how do they compare to an action packer?
Old December 3rd, 2012, 11:11 AM
winn442's Avatar
winn442
Winn Bearden
They are harder plastic compared to an action packer, so I imagine they would be easier to crack if you treated them roughly. The lids are slightly recessed so the ones on top fit nicely, I used industrial Velcro on the lids and bottom of the boxes, so they usually stay put.
Winn Bearden
Old December 3rd, 2012, 11:12 AM
Very nice. How do you have your Office Depot boxes secured back there? And how are you securing the stuff to the clothes hanging rods?
Old December 3rd, 2012, 11:20 AM
winn442's Avatar
winn442
Winn Bearden
I have a box surrounding the rear A/C that holds speakers, and it's taller than the wheel wells, so the bottom boxes are a snug fit between it and the sides. The tops boxes "nestle" in the lower lids and industrial Velcro holds them well. I'm sure they would probably shift during hard off roading, I would then probably take them out or rig some type of straps around them.
Winn Bearden
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
I dunno man, anything burning propane or whitegas in an enclosed tent sounds dangerous to me. Keep it well vented. Carbon Monoxide has no smell.
Old December 3rd, 2012, 11:21 AM
winn442's Avatar
winn442
Winn Bearden
the stuff on the rods are a press fit between the rods and the roof.
------ Follow up post added December 3rd, 2012 11:26 AM ------
I've used a Coleman Sport Cat inside tents for years....but I'm going to be cautious with this gas burner and take a CO alarm with me....
Maybe that's the reason I'm dain bramaged......
Winn Bearden
Old January 16th, 2013, 04:54 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
What kind of fuel are you using for the Whisperlite? Kerosene or White Gas? My local Dick's Sporting goods sells the Coleman Camping Fuel (aka White Gas) for $13.99/gallon.
I'm trying to figure out what kind of fuel I want to use so I can figure out a stove. Was thinking about a dual burning white gas/gasoline stove to give me options.
