Overland Showers - Defender Source
Old October 22nd, 2014, 09:13 AM
The Dro
Dro
1988 Ninety
Overland Showers
At Expo I saw this kool contraption that attaches to any roof rack:
The price tag for the shower is $300 (she's unobtainable ).
At first the price seemed ridiculously high.
But, After doing a quick estimate on how much it will take to manufacture my own... The price was $275 for parts only. (using 6063-T52 aluminum rectangle tube, low pressure relief valve, fittings, hose, filler neck, etc). A 3" x 6" x 60" 6063-T52 aluminum rectangle tube will hold 3.8 gallons of water without taking in consideration the hose.
PVC is out of the question due to its low thermal conductivity.
Anywhoo...
What do you guys use? Without shelling out 300 clams?
Old October 22nd, 2014, 09:18 AM
the rover shop
shayne young
No woman is unattainable.. Just gotta have an Aussie accent to do it..lol.. Ay Jonesy..
------ Follow up post added October 22nd, 2014 09:22 AM ------
I did one out of PVC and painted it black and trust me, that water got hot throughout the day..but yeah, 300 clams doesn't seem too bad..just make sure you don't hit anything low laying with that thing..
Old October 22nd, 2014, 09:28 AM
The Dro
Dro
1988 Ninety
That was the first inexpensive solution I thought off. But, I ruled PVC out because of its low thermal conductivity...
Since you have effectively used it, I have a few questions:
PVC 40 or 80?
What diameter pipe? 3" or 4"?
Old October 22nd, 2014, 09:41 AM
The Dro
Dro
1988 Ninety
C'mon Pedro. All of this crap can wait. You need to get the truck first. Then get is sorted mechanically. Only then should you be looking at flair.
-Jeff
Technically (or literally) it can't. This year alone I've done 3 (4 with URE) events and I plan on taking the kids next season now that they are older.
I smelled like a bear out of hibernation after Expo and had same issues when I went to RC.
I'm giving up on a D
I'm "flaring" what I have.
Old October 22nd, 2014, 09:45 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I've used a few different things..
I have a Zodi outdoor shower (http://amzn.com/B003EEESPW) ... but I never really liked it... the water temperature was never consistent, it'd either be cold or scolding hot. Pressure wasn't that great.
I've also used a Nomad H2O to Go (http://amzn.com/B0024M3OJ6) ... there are a couple of different models, one with battery, one that is just 12V... it has great pressure... you just need to warm up some water to put into the reservoir
Also, just regular solar bag camp showers aren't bad.. they do the job and are the cheapest.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 22nd, 2014, 09:54 AM
The Dro
Dro
1988 Ninety
Thanks Ryan.
I had in mind this way before I went to Expo:
http://www.amazon.com/Stansport-Caba...dp/B00DYVQGB4/
www.amazon.com/Docooler-Gallon-Camping-Hiking-Outdoor/dp/B00KT5IA5S
Can't beat the $55... But now you have to store more stuff
Old October 22nd, 2014, 10:02 AM
Pedro,
There were showers @ Conclave. There was a shower trailer 100 yards away @ Expo. There are showers @ the camp @ Uwharrie. You want to wash your junk out in the open out of a piece of black pipe on your roof rack? Help me understand
Old October 22nd, 2014, 10:12 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Pedro,
What he said.
I only smelled Erik over at Lucky8....
Rent my
Old October 22nd, 2014, 10:13 AM
ezzzzzzz
Mark Garrenton
Bottomline, those things only hold 5 gallons of water. That will provide an okay rinse off but not much else. Add the fact that it's gravity fed with steadily reducing pressure as it empties. No thanks. I had an old ChrisCraft water/oil cooler that was plumbed into a 45psi 12v pump and 13 gallon tank under the chassis ('71 IIA). That worked like a charm. If it's worth doing it worth doing it right. Here is several viable options though they do take up a bit more room...but only when actually needed. Just convert to a handheld shower head and pump through a propane water heater.
http://www.northerntool.com/shop/too...-spot-sprayers
The Dro
Dro
1988 Ninety
Pedro,
It's more than showering. You can clean stuff, have additional water stored if needed. There are endless uses for water.
And no... I'm not planing of showering on my birthday suit. You guys cannot afford the therapy after that scene.
Good to know URE has showers. (I know Cove has)
------ Follow up post added October 22nd, 2014 10:17 AM ------
That's the drawback and why I haven't pulled the trigger.
Old October 22nd, 2014, 11:14 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Pedro,
i don't think pedro means to doing HIS junk washing out in the open, it was for the other user
Old October 22nd, 2014, 11:19 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by The Dro View Post
At Expo I saw this kool contraption that attaches to any roof rack...
Bottomline, those things only hold 5 gallons of water. That will provide an okay rinse off but not much else... gravity fed with steadily reducing pressure as it empties...
Mark made some good points regarding drawbacks.
I think the other drawback is that the only means to heat the water is the sun, so the wait time for warm water is what the outside ambient temp + some solar factor can provide which is useless for half the year in our climate don't you know.
RDavisinVA
Old October 22nd, 2014, 11:24 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I just picked up this thing. Haven't tested it yet but it's supposed to be a good unit. It has an internal battery to power the pump as well as AC and DC plugs. Propane only fires up when water is being pumped and you use an external water source such as jerry can, bucket or river. It's supposed to heat water 45 degrees over standing temperature.
Old October 22nd, 2014, 11:29 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Jeff:
Looks like a good unit in the same price range as the Overland Shower.
RDavisinVA
Old October 22nd, 2014, 11:34 AM
87 D110 (Ruby)
Pedro,
Reading this I was going to post the exact same thing Doug!!! Aint nobody wanna see Pedro's junk ---- dude unless you are in the freaking wilderness Pedro you do not need this.
THERE ARE MANY MORE IMPORTANT THINGS YOU NEED TO DO TO THAT DISCO...but once again...it is Pedro!
Old October 22nd, 2014, 11:45 AM
Heat up some water on yer camp stove. Pour it into a $15 garden sprayer. Pump it up and boom, shower. You can get a pretty good bath with a 2 gallon one.
Very old sailboater trick for small boats with no hot water system or room in the head.
Old October 22nd, 2014, 11:46 AM
I have a Zodi outdoor shower (http://www.amazon.com/ZODI-Outback-G...ds=zodi+shower) ... but I never really liked it... the water temperature was never consistent, it'd either be cold or scolding hot. Pressure wasn't that great.
I have a Zodi as well. They work great, are low cost, and take up little room. You just have to learn how to use it and you should have no trouble with consistent and correct temperature for a full shower.
Old October 22nd, 2014, 11:59 AM
A bottle of Axe cologne and you will be smelling like a skinny pants wearing hipster.
Old October 22nd, 2014, 12:21 PM
The Dro
Dro
1988 Ninety
Jeff.
Thanks for the info. Let me know how it performs.
P
Old October 22nd, 2014, 12:29 PM
Schedule 80 PVC is for higher pressure, PVC Schedule 40 can handle pressure as well, and should be fine. Personally I think what you have with this "solution" is essentially useless though.
-3.8 gallons? And you plan to use it for you, your wife and kids, and extra water supply?
-Showering with one hand sucks. You'll use more water than if you were using two hands.
-There are showers at just about every single event. If your argument is that you can also use this for additional water supplies, then I would figure out something better suited for those water needs (like jugs of water) and shower at the facilities provided.
-Most of the best Rover events happen in the Fall-late Fall-Winter, i.e. it's colder out.
-Showering outside when you're at the beach is awesome. Showering outside in the Fall on a chilly morning on the frozen dew with a light breeze, no curtain to block the wind, while trying to rinse off with one hand and your loofa, and the garden hose in the other will blow. You and your kids and your wife will see Gustavo stepping out of one of the luxury showers provided at some events, looking refreshed, and you'll have a family of deserters - you'll be the only one left using your shower for the rest of time, just to hold on to some little bit of pride for creating such a masterpiece.
Overland Engineering RBees Misc. Chit-Chat 4 September 18th, 2008 10:54 AM
Lots of Land Rover content in Overland Journal Negative Earth The Vendors Loft 4 April 28th, 2008 11:30 PM
Off Road Training weekend - Overland Experts in CT 3/29 & 3/30 pmd Trips, Trails and Events 2 March 19th, 2008 08:05 AM
Overland Experts - winter drving.... dmarchand Trips, Trails and Events 5 October 2nd, 2007 05:02 PM
