Over temp indications??? - Defender Source
Old August 14th, 2013, 05:09 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
This is on my '97 D1.
The temp gage is pegged. Using an infrared thermometer the thermostat housing shows 250 while the top hose shows 170, mid-length to the radiator.
Ergo, I need a new thermostat. Correct?
Old August 14th, 2013, 07:56 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I don't know what they sell in Guam, but be sure you get the 88c OE or a 180f if it's a thermostat from the US.
All the books list a 195 in the US which is too hot. US thermostat temps are when they start to open, not when they are fully open, like the 88 OE is.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 14th, 2013, 09:48 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Everything in Guam is U.S. standard.
If the local Rover dealer has one, I will assume they have the correct one. If I have to buy from NAPA, I will ask for the 180.
Wont run at temp Neo Defender Technical Discussions 12 February 24th, 2006 06:54 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
