Operation "85Red110's Truck" Phase 2: The Build - Page 7 - Defender Source
Old September 11th, 2014, 09:17 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Sorry I'm not so timely in responding, Charles. Just got back from TX with Bill Adam's new ride. I serviced both T-case and trans. I dumped both diffs. after teardown. They both need lube since cleanup/paint.
Sounds like you guys made good progress while I was out. I hope to be over Sat.
Old September 11th, 2014, 09:36 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
*Sunday
1985 Land Rover 110 3-door ST
Old September 11th, 2014, 11:11 PM
No problem Ron. I forgot about the trip - no drama then?
Does anyone have any rover brake fittings? We need one female and one male fitting to get the brakes buttoned up.
Time lapse of Wednesday night's work:
http://cdn-2-service.phanfare.com/im...1bad26bf5b6_12
Originally Posted by pendy
I'm here for the D's
Old September 11th, 2014, 11:12 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by cgalpin View Post
No problem Ron. I forgot about the trip - no drama then? Does anyone have any rover brake fittings? We need one female and one male fitting to get the brakes buttoned up. Time lapse of Wednesday night's work: http://cdn-2-service.phanfare.com/im...1bad26bf5b6_12
I have them for you but won't be until next week until I can get then and send out
Old September 11th, 2014, 11:13 PM
Ugh. We really need them by sunday to make getting it running by conclave a reality.
Old September 11th, 2014, 11:19 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
They are the same as a disco, so if some one has a parts disco near you just rob them from there
Old September 11th, 2014, 11:21 PM
I'm hoping Adams can pull one off one of his parts RRCs. Bill, you going to be coming this weekend?
Otherwise Kent, maybe you can make a trip to a junk yard tomorrow morning?
Old September 12th, 2014, 12:12 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Don't have to ask me twice. Kid in a candy store.
Old September 12th, 2014, 06:11 AM
I'll see what I can do.
Old September 12th, 2014, 07:30 AM
87 D110 (Ruby)
Charles - I have a bag of brake parts - courtesy of grumpy Bill
Will bring em over
Old September 12th, 2014, 08:34 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I'm still gonna go frolic around in a junkyard this morning, just for fun. You can't stop me.
Old September 12th, 2014, 09:20 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Kent can you keep an eye out for an LR3 or Range Rover tow hitch attachment
MUDSUX
Old September 12th, 2014, 10:24 AM
I need some Disco II marker light wiring ends! NOT the actual marker itself (I have those), but the actual male wiring harness/end that is on the truck. If you pop out the marker light, you should be able to pull enough of the harness out to cut a good length.
A couple of representative pics below, but again NOT the marker light itself but the wiring harness end that it plugs in to. Need both side/2 total.
Name:	disco marker.jpg
ID:	102753   Click image for larger version
Name:	marker light.JPG
Old September 12th, 2014, 10:42 AM
Same part used on the late td5 defenders. I have a template for the hole to cut in our fender if thats what you are up to. Ping Randy Williams and he can bring you the pig tails since he's camping with us next weekend.
I can scan the template to you if you need it.
Old September 12th, 2014, 10:50 AM
Bingo!!! YES on the template, that would be awesome. Will the scan of the template retain it's dimensions/ratio for cutting out? If not I'm sure I can adjust it accordingly.
I'll drop Randy a line...I forgot he was coming down!
Old September 12th, 2014, 11:02 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Went to a local salvage yard because one of the guys who worked there told me over the phone "sure, we have a Land Rover back there somewhere...."
Turned out to be a P38 that was completely picked clean. However, they did have a very nice 94 Jag XJ6..... so voila! I have some nice Jag brake fittings! They might work, but if not, I still had fun.
Sorry guys, no Land Rover luck.
Kent
Old September 12th, 2014, 12:27 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Hit up Widewater Pick and Pull down below Quantico. You can check their inventory via the PDF which is an approximation for what you might find there. I prefer that one to their Fredericksburg location, have had very good luck there and it's always fun to just wander the rows to see what's what. Don't take Tony Brooks though, he'll never leave the parking lot for love of the Senioritas running the food truck...
Old September 12th, 2014, 02:34 PM
Should. To be candid I had to open things up a bit beyond the template. What tool are you using to make the hole ? I used two different die grinders
Old September 12th, 2014, 03:34 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Anybody in NOVA have a ROW header bar I can borrow until I can take the truck down to Brewie to have the actual top fitted? I found my bimini/bikini top in the attic, and Galpin already has a hoop I can borrow. Already have the gutter kit too(thanks Pedro!) Just need the header bar. TIA.
Kent
Old September 12th, 2014, 04:18 PM
I've had one FS for a few months. You could just buy it...
Kent
110, d110
Operation Get Kent aka 85Red110 His Truck Back!!! rijosho Misc. Chit-Chat 611 August 26th, 2014 08:21 PM
