Operation "85Red110's Truck" Phase 2: The Build - Page 6 - Defender Source
Old September 9th, 2014, 09:05 AM
Originally Posted by cgalpin View Post
Parts are starting to come in (thanks lucky eight) and expect more from safariHP later in the week.
I'm going to try put some time into the truck on Wednesday evening to increase our chances of getting it drive able on Sunday. If anyone can lend a hand, let me know.
I'm in for Wed eve...what time we talking?
Old September 9th, 2014, 09:08 AM
I'm a maybe also.
Old September 9th, 2014, 09:55 AM
One black wheel? Trying to start a new trend?
FYI Charles tore a sidewall on a trail with very sharp rocks at Rausch. I lost a bead, I believe Jeff did also, all in rapid succession. I think Lav was the only one who made it unscathed. It was quite comical, if it wasn't for the constant downpour of rain.
It's just really hard to find a lone tire of a given size and brand that has the same or similar level of wear as the other tires on your truck.
Old September 9th, 2014, 10:28 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Hows cash on hand? I noticed soliciting for cash donations has fallen off...
Old September 9th, 2014, 11:36 AM
Now, I wouldn't call it "unscathed"...that was the same trail I broke a diff on last year (ironically also in a downpour rain storm)! I just made it through ok on THAT trip - but it certainly had it's fun with me previously.
Old September 9th, 2014, 12:10 PM
Let's say 5pm on.
Bill, you are correct, but it was the last thing we were going to do until we ruled out other issues. The difference is obvious in retrospect, but...
It would be awesome if we had a decent turnout. It would make Sunday doable instead of a mad rush. I have a busy day/night today but will try make a complete TODO list so you can see what we are facing.
Originally Posted by pendy
I'm here for the D's
Old September 9th, 2014, 12:18 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Let's say 5pm on. Bill, you are correct, but it was the last thing we were going to do until we ruled out other issues. The difference is obvious in retrospect, but... It would be awesome if we had a decent turnout. It would make Sunday doable instead of a mad rush. I have a busy day/night today but will try make a complete TODO list so you can see what we are facing.
I can make it for a bit.
Jimmy Buffett
Old September 9th, 2014, 12:22 PM
Bill Larson
Bill Larson
Well I'm there in spirit...love the time lapse stuff! I volunteer Brooks in my stead!
Old September 9th, 2014, 12:25 PM
Who is this "Brooks" character?
Old September 9th, 2014, 12:43 PM
Just rattling yr chain CG
Old September 10th, 2014, 05:03 PM
The name Brooks does sound vaguely familiar...
A big thanks to Pendy, SafariHP, and Lucky8 for parts shipments!
Ok, here is the current punch out list
  • install springs and shocks
  • install longer bolts that hold a-arm to frame
  • install fuel pickup/sender and hookup fuel lines at rear
  • make hard brake line for front right side
  • hook up soft brake lines
  • hook up last bits of heater hose
  • paint and install coolant reservoir, fill coolant
  • install fan shroud
  • make pcv catch can
  • wire up alternator and distributor
  • check/set timing (static)
  • try start it
  • make sure diffs are drained of any water and refill with oil
  • check fluids in LT230 and LT77 (or Ron pls confirm)
  • install seat box
  • install seats
  • install tunnel cover and floor boards
  • take to exhaust shop to get exhaust mod made to clear crossmember by header
  • check/tighten suspension bolts and tighten drag link nut.
  • install cotter pins on all nuts requiring them
  • install driveshafts
And stuff we need to wait on parts for
  • install left rear brake wheel cylinder and then hub and drum.
  • bleed brakes
  • install bumper when we get bolts
  • install front grill
And non-critical, nice to have stuff
  • check wiring for headlights etc.
  • re-cover tuffy console pad
  • install tuffy console
  • check alignment (tape measure) and see why there is play in steering box
  • top coat bumper with extreme chassis black (POR15 isn't UV stable)
Old September 10th, 2014, 05:07 PM
if you have some extra work clothes, I'm in
Old September 10th, 2014, 05:14 PM
Wrapping up some work stuff, quick dinner with the kids, and I should be over 7/7:15ish
Old September 10th, 2014, 05:19 PM
sure
Old September 10th, 2014, 05:35 PM
87 D110 (Ruby)
momma Jones is working this weekend (I hope) so I should be free Fri - Sun to help
Old September 10th, 2014, 06:03 PM
Crap, things are not looking good.
We can't install the springs and shocks because Kent has the spring perches (haven't gotten the ones we were waiting on so are painting the old).
The connectors I bought from FedHill are not matching the soft brake lines. Bill, I bought the british/girling stuff, P4-3 female nuts and they don't fit the soft lines. Can you confirm these are the kind I should have bought?
Still lots to do though. See the video feed for Tyler and I in action.
Old September 10th, 2014, 10:40 PM
flippedrover
Tyler
'94 D-90
Playing with my FlirOne.
Jimmy Buffett
Old September 10th, 2014, 10:42 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
You guys have all the fun the one time I can't make it out there.
Kent
Whose feet are those? He has shoes on, so I'm guessing it's not Charles....
1985 Land Rover 110 3-door ST
Old September 10th, 2014, 11:34 PM
Ha, you'd be wrong then! I blew out a pair of flip flops last weekend and don't want to get my last "good" pair dirty so I am wearing my old steel toe'd shoes from the army.
Kent
Thanks to Tyler, Jason and Ed for coming by and helping out.
Done
  • paint coolant reservoir
  • install seat box
  • install seats
  • install driver side rear hub (replace seal) and axle shaft
Remaining
  • install fuel filler neck (need clamps)
  • close up LT230 rear housing cover
  • make hard brake line for front right side <- figure out connector issue
  • install coolant reservoir (after shock towers), fill coolant
  • wire up starter
  • try start it
  • install seats
  • bleed brakes
Old September 11th, 2014, 12:04 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Holy cow that was one hell of a wrenching session! I'm bummed that I missed it. Thanks for all your help guys. Sounds like we might have a running truck this Sunday B-)
Kent
110, d110
Operation Get Kent aka 85Red110 His Truck Back!!! rijosho Misc. Chit-Chat 611 August 26th, 2014 08:21 PM
