Operation "85Red110's Truck" Phase 2: The Build - Page 4 - Defender Source
Old August 24th, 2014, 10:35 PM
phoenix37's Avatar
phoenix37
john
Kent that brings up an interesting point. Would it of taken less time to pull the body off, blast it and then por 15 rather than leave the body on? My 109 is due for a similar frame treatment and I'm reluctant to pull the body for fear ill never get around to putting it back on!
Old August 24th, 2014, 10:46 PM
That would be the case for me! If you go so far as to pulling the body off, you should just have the chassis galvanised.
Old August 24th, 2014, 10:50 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Probably not. We were able to disassemble, clean, and paint in just two full saturdays. It probably would have taken longer if we took the body off, but I imagine the reason for that would be because we would have taken advantage of the complete disassemble and done more work to the individual parts, effectively turning this into a full-on restoration.
1985 Land Rover 110 3-door ST
Old August 24th, 2014, 10:53 PM
And Charles would then be divorced.
Old August 24th, 2014, 11:24 PM
Yeah we have already crossed the line of doing too much, but pulling the body would have been a lot more work especially when ship fitters sets in. If the engine and transmission were still out when we got it, it would have ben damned tempting because the bulkhead needs work. But the goal is to get it going with a decent foundation and nothing more. It can't live in my garage for too long and Kent wants to drive it anyway.
Originally Posted by pendy
I'm here for the D's
Old August 25th, 2014, 08:36 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Looks like it is coming along really well
Congrats guys !!!
legend in my own mind
Old August 25th, 2014, 12:06 PM
87 D110 (Ruby)
Donna doesn't mind so long as she gets to see me every weekend....
Old August 28th, 2014, 08:38 PM
Bump. 9am Saturday till ...
Old August 29th, 2014, 12:51 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I'm there depending on how my arms feel. I did something to both biceps moving 300 pound file cabinets at work this morning.
Jimmy Buffett
Old August 29th, 2014, 10:48 PM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
See you in the AM.
Old August 29th, 2014, 11:26 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Received a couple boxes of parts today from our good friends at Lucky8. Thanks Justin!
Going to get a lot done tomorrow. Cant wait! Ill bring beer and donuts.
Old August 30th, 2014, 02:58 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Received a couple boxes of parts today from our good friends at Lucky8. Thanks Justin! Going to get a lot done tomorrow. Cant wait! Ill bring beer and donuts.
Justin is good people.
This truck better be at Conclave!
Semper Fi!
Old August 30th, 2014, 04:04 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Elbows deep applying Bill's Electrickery 101 this weekend.
Old August 31st, 2014, 11:22 AM
Will try make time for an update tonight, otherwise it will need to be tomorrow. Just wanted to say that we will be at it again tomorrow from 7-11am in order to have a realistic goal of getting the suspension put in next weekend and getting the truck running since I can't work on it the following weekend and the conclave is the next. If you have the time, please join us
Old August 31st, 2014, 10:08 PM
Ok, I captured images every 3 seconds of yesterdays wrenching session and then came inside and deleted them afterwards (by accident - don't ask). So no time lapse this time, sorry.
Ron, Bill, Jason, and Jonesy came to lend a hand. Ethan did an amazing job of keeping himself entertained all day. Jason remind me next time to introduce him to my neighbors 4 yr old - they would get on famously.
Ron pegged away at the engine hookups and Jason and Bill rebuilt the steering knuckles and put the front axle back together. We ran into an issue with interference between the hub and the caliper which we need to solve, but it was otherwise a good days work.
Kent put POR15 on more stuff, installed the bump stops and tried to get the exhaust hooked up. The header has a larger output than stock piping, and is also pointed too close the crossmember so we'll take it to a muffler shop once it's running to get sorted, but we did get the existing pipe we had expanded so it would go onto the header and do some test fitting.
I am not sure what the hell I got done. Seems like nothing. I had to go buy some metric taps and other supplies (and lunch), and then a trip to the muffler shop, but don't recall getting much else done. Oh I got the rest of the wheel studs pressed in...
Jonesy stole some tires.
At the rate we are going, we are at risk of not getting this thing done by conclave so are putting some time in tomorrow. Tomorrow we hope to get the fuel tank in and the rear brakes buttoned up and if we have time, some more hookups at the engine, and I still need to get the a-arm ball joint pressed in. We can't install the suspension until the bushings come in.
Thanks again to everyone who has lent a hand.
Old August 31st, 2014, 10:13 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
.... We can't install the suspension until the bushings come in.....
...and we can't install suspension until the suspension comes in either. :P
Thanks to all the guys for coming to help out. Another great wrenching session in the books.
Kent
Old August 31st, 2014, 10:37 PM
Oh, here are a couple of pics
ID:	101910 Click image for larger version
ID:	101906 Click image for larger version
Old August 31st, 2014, 10:48 PM
Only the cool kids run mismatched rims. And the lazy who don't give a damn what their rims look like.
You might be on to something about the shoes.
Old August 31st, 2014, 10:52 PM
Only the cool kids run mismatched rims. And the lazy who don't give a damn what their runs look like.
That reminds me...get a spare before Conclave!
Old August 31st, 2014, 11:07 PM
I don't think the project should be pushed to meet a deadline. Conclave would be cool but there will be other events.
110, d110
Operation Get Kent aka 85Red110 His Truck Back!!! rijosho Misc. Chit-Chat 611 August 26th, 2014 08:21 PM
