Operation "85Red110's Truck" Phase 2: The Build - Page 10 - Defender Source
Old September 16th, 2014, 10:48 AM
Rover Lover's Avatar
Rover Lover
Ron Dade
97/D90 Soft Top
Would you believe...
...it got rubber in every gear! Yeah, the tires rolled along the ground, that is! Once we got it primed with fuel, started right up. Had to work with the throttle adjustment to get the revs set for idle. Seemed quite smooth running, but I left prior to the actual test drive. We could only get the starter to crank it by jumping across terminals with a screwdriver while someone switched ignition to start position (engaged solenoid). Still need to sort that bit.
Old September 16th, 2014, 08:08 PM
Ok, convinced the starter is just a bad solenoid after cleaning all connections and adding another ground wire. I can get it to start with the key 1/10 times or so.
Kent, I think the coolant leak is either the little triangular blanking plate or the housing for the thermostat. The blanking plate should be a good one to start with - pull and put some right stuff under it and replace, test.
I locked own the throttle cable and adjusted the idle so that's done.
I am out of time until thursday afternoon.
If it were me on Thursday, I would fix the coolant leak, tighten the rear crossmember nuts, put together a filler solution and run down to the muffler shop. The rest is easy and we can even do some at the conclave if needed.
Originally Posted by pendy
I'm here for the D's
Old September 16th, 2014, 08:21 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Aye aye, Captain. Im on it.
Kent
1985 Land Rover 110 3-door ST
Old September 16th, 2014, 09:43 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I am sure you can get some extra help at the conclave Kent. Just make a checklist of things to keep track of during your trip out there and try to get there safely. Plus try to have some parts on hand at the event so you can make some more progress when others offer help.
Surely it has got to be more fun to go to an event in a rattle trap Land Rover then to show up in a car and just drool at everyone else's LR. Things will get sorted out over time on your Defender.
legend in my own mind
Old September 23rd, 2014, 08:56 AM
87 D110 (Ruby)
Well he got there safely! Here we are rolling from my place...
Old September 23rd, 2014, 07:07 PM
Lots of pictures of it at the Cove in the Conclave thread too. If you saw those you'd also have seen that Kent and his new truck did amazingly well on the trails.
We had one minor problem, which was a drag link ball joint nut fell off at some point and the drag link popped out while riding trails on Thursday evening. Fortunately nothing got damaged and with the help of Jason and Jonathan, we got a replacement nut and got her going again. If only someone had taken the time to remind us to put cotter pins in. LOL
He still has a long way to go, but it's officially a runner and he took it home!
Thanks again to everyone for the support and donations.
Jim, I got the knob and catch can thanks. Will see what we can do with the can, but I was also thinking it might be worth trying to fit a nipple on the back of the filter plate. I assume there is a fair amount of suction into the carb - is it ok to have it sucking crankcase air in all the time from a decent sized tub (1/4 - 3/8" I think) or does it need to be restricted?
Old September 23rd, 2014, 07:36 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Makes for a great tree hauler! Great work Charles & crew
Old September 23rd, 2014, 09:14 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
This pic really confused me...thought it had morphed into a lhd for a second. Awesome that it runs though, great work all around
Old September 23rd, 2014, 10:03 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Really glad to hear Kent got there safe and had lots of fun. That is a high point in all this for me.
Pictures look great but would be fun to see some more here.
I agree Charles to restrict the return hose to the intake manifold somehow makes a lot of sense to me also. With that catch can it will never have trouble breathing though. Obviously it is made for a diesel engine from Allard.
Should I still send the tailgate to your home address Charles? Or Kent do you have an address you want me to send the tailgate to?
------ Follow up post added September 23rd, 2014 09:11 PM ------
Heard from Kent. Told me the outing was the most weekend fun he has had in a while !!!!
Thanks to everyone to help him out with this.
Charles, Kent gave me his address and I will send the tailgate along to him.
Old September 29th, 2014, 05:22 PM
Thanks Jim, you rock!
In case anyone in the Raleigh area is watching this thread but not the board as much as they would like, Brewie is trying to get a wrenching weekend going down there to do the cage and bulkhead work:
http://www.defendersource.com/forum/...ad.php?t=56697
Old October 3rd, 2014, 06:25 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Still need ST door bottoms. Help!
We are nearing the end of the operation, but need one last push to get the truck there. If anyone out there has some rust free door bottoms, I would greatly appreciate hearing from you. Thanks in advance!
Kent
Old October 5th, 2014, 12:20 PM
Bump!
Old October 6th, 2014, 04:13 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Installed the other Foley side locker this weekend!
Still looking for a good set of ST door botttoms... Anyone?
Kent
Old October 6th, 2014, 04:17 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by 85Red110 View Post
Installed the other Foley side locker this weekend! Still looking for a good set of ST door botttoms... Anyone? Kent
i know someone that might have a set or four. When you come down we can talk about them.
Old October 6th, 2014, 04:20 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Brewie is the man!
Old October 9th, 2014, 03:36 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Blue stripes removed. Winch installed (mostly)
Many thanks to Jonesy for the winch! This thing rocks.
Old October 9th, 2014, 03:51 PM
So how did you get the stripes off?
Old October 9th, 2014, 04:08 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Heat gun, razor blade, Goo Gone, and about 4 hours of frustration and cursing.
Not that the truck didn't need a paint job already, but now kinda definitely does.....
Old October 9th, 2014, 04:28 PM
Patina is a good thing!
Old October 9th, 2014, 04:39 PM
grnrvrs's Avatar
grnrvrs
Paul
88
When I removed the stripes from my 110 I used a pneumatic eraser. It was awesome.
1970 SIIA 88, Sold
110, d110
Operation Get Kent aka 85Red110 His Truck Back!!! rijosho Misc. Chit-Chat 611 August 26th, 2014 08:21 PM
