One day engine out. - Defender Source
Old February 28th, 2010, 01:32 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
One day engine out.
Well, it took all day but I was able to drive the D90 in the drive way in the morning and by the evening the engine, transmission, and T-case were out, the engine is now on a stand and the transmission is separated. I didn't think I could do it in a day just by myself, but there you go! Very happy with the progress as tomorrow it looks like snow.
Old February 28th, 2010, 06:35 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Took it all out in one chunk? That must have been fun to balance.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 28th, 2010, 12:11 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yeah, although "fun" is a tricky word! The real question on the whether or not it was worth doing in one chunk will be if I decide to put it back in one chunk. There are definitely drawbacks, but I don't think I could have removed it in one day doing it piecemeal. Odds are, I will attempt to reverse the same procedure. As a few have said, one lump is easier than many lumps.
Old February 28th, 2010, 02:11 PM
phoenix37's Avatar
phoenix37
john
Could you remove just the engine in one day? How many people would it take?
Old February 28th, 2010, 02:49 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yes, I removed my RRC's engine and the D90's engine in a day, one person. It is easier than doing the the big lump of both. Seems I always do these things by myself. Really the only time you need another hand is to help the navigating but even that if you take it slow and smooth, one person is fine.
Old March 1st, 2010, 11:39 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
What's up with your current drivetrain?
Old March 1st, 2010, 11:57 AM
With engine crane, about two to three hours depending on condition of fasteners. The trick is to remove the exhaust and manifolds, raise the engine enough to get the rubber mounts out and then lower the whole mess onto the frame rails. This allows a little better access to the otherwise unattainable bellhousing bolts. I had to use a combination of several different 9/16ths wrenches...one offset end wrench, one regular end wrench and a couple of odd wobble extensions, one 18" extension and one stubby wrench handle. Each bolt requires a slightly different approach. I was standing on the frame rails inside the engine bay and reaching down behind the heads for the uppers and on my back underneath with the long extension for the ones on the side.
One people.
Old March 1st, 2010, 03:41 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Jamie,
The current driveline is actually in decent condition except that the 1st to 2nd and 4th to 5th synchro are a little loose--my wife doesn't like that, so she told me to fix it. ;-) I don't get that kind of "permission" to change things that often. Let me know if you need a used LT77!
Old March 2nd, 2010, 10:58 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Originally Posted by Davis View Post
Jamie,
Gotcha You going to upgrade to an R380?
engine
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
