Oh heck, Rust! - Defender Source
Old April 14th, 2005, 04:19 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Oh heck, Rust!
Power washed the disco the other day, not good!
Ended up cutting a 1 ' long strip out of the chassis and butt welding in a 3mm thick patch. Then a pin hole appeared on the inside of the chassis rail so that got cut out too. Bit of a blow, should have cleaned the whole area properly. P.I.T.A to cut out having already welded up the bottom
Needless to say the rear shocks were replaced
There was then a long session with the waxoyl gun on the internal chassis rails
ID:	2982   Click image for larger version
Name:	rust cut out.JPG
ID:	2984   Click image for larger version
Name:	waxoyl time!.JPG
Mike Hammond
Old April 14th, 2005, 09:15 AM
Ewww, I hate that kind of stuff, rust! But that is a nice patch job you did. Did you paint before you waxoyled?
Old April 14th, 2005, 12:05 PM
draaronr's Avatar
draaronr
Here
LR3
Cancer of the metal sucks. hey how about that jack? what was that for?
Old April 14th, 2005, 01:28 PM
mikeslandrover
Mike Hammond
The jack was to create a little more head room, I just stretched the springs out a little, it was safe, honnest
Yep lashings of paint on first.
Pressure washed the ninety this afternoon. Guess I'll be getting the welder out again soon
Not so distressed about the rust in this case 'cause the truck is 20 years old, been used on a farm and kept outside for all its life. took months to extract all the straw from the nooks 'n' crannies.
Pics to follow when the weather is better!
Mike Hammond
rust on SW top overlap kolvedic Defender Technical Discussions 0 December 5th, 2005 01:51 PM
fix for rust on rear crossmember/bumper d90_1372 Defender Technical Discussions 2 August 6th, 2004 08:38 AM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
