now here is a tire - Defender Source
Old May 20th, 2004, 01:30 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
now here is a tire
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Legend in My Own Mind.
Old May 20th, 2004, 01:34 PM
Do you think I can get them to fit with minor fender trimming? They are not to far from me and $500 is a great price!
Old May 20th, 2004, 01:49 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Good Gravy those are huge!
Old May 20th, 2004, 02:36 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Yes, you should be able to. However, you need to get new wheels in 16" rather then your 15's.
True, for that price you should get them.
Good luck,
Old May 20th, 2004, 02:42 PM
I have 16" rims I would need 20" rims for those bad boys. Do they make 20" spinners that can handle 52" tires?
Old May 20th, 2004, 02:55 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I was just playing with you
As for the 20" spinners, anything is possible with $$$
World traveler
Old May 20th, 2004, 03:08 PM
Well in that case then I'll make some spinners out of quarters and 1/2 dollars and save myself some cash!
Those tires look a little heavy, what do you think the local tire shop would say if I rolled in on those and asked to have them balanced and rotated.
And do we all agree that the stock spare tire holder can handle the weight of a 52? You guys will help me change it if I get a flat on the trail right? Guys! Guys! hey where did you all go?
Old May 20th, 2004, 03:26 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Those bad boys you would have no trouble mounting yourself and then the BB trick would take care of you. Imagine trying to cary a spare anywhere on the truck. No way. You would not need one anyway. Run it with beadlocks, even flat the sidewall would not bend completely, 9-ply! I want them
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 20th, 2004, 03:41 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
LOL...I saw that too Randy...
With our wheelbase being as it is, I think those tires will hit each other....
Glenn
Old May 20th, 2004, 03:51 PM
Glenn, LOL I can just see it one tire rubbing the other LOL!
Dave I just want too see the look on the tire guys face when he sees the tires. I know most people who run these bad boys also run 2.5 ton axles but I think my Rover axles are up to the task.
Old May 20th, 2004, 06:10 PM
Glenn_Guinto
Glenn Guinto
Talking
Actually Mike, I stand corrected...they fit but with very little room to spare....
Glenn
Old May 20th, 2004, 06:13 PM
Glenn_Guinto
Glenn Guinto
LOL...for some reason, the word that comes to mind when I look at that picture is "Double D's"
Glenn
Old May 20th, 2004, 08:01 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
LOL. I guess the tire carrier could handle the big tire. LOL
World traveler
Old May 20th, 2004, 09:08 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Glenn did you ever come across any 8.25's?
Old May 20th, 2004, 10:17 PM
Glenn_Guinto
Glenn Guinto
Randy, we have a few leads but nothing concrete yet. I'll let you know as soon as we get them. Thanks!
Glenn
Old May 21st, 2004, 08:14 AM
WOW Glenn! I thought you would have better flotation with those on your 90. I'm glad too see they fit without rubbing. I like the monster truck approach you took to get them to fit (tire outside of the wheel well). What did you use 12" spacers? And Yousef you are right they will fit on a 16" rim!
ROTFLMAO
Old May 21st, 2004, 08:41 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Cool Glenn thanks... As for the tires in glenns pic, I might have put some monster coilovers in and jacked the entire body above the tires.... lol
Old May 21st, 2004, 09:31 AM
Glenn_Guinto
Glenn Guinto
It's all about low center of gravity Randy....
Actually, you guys might not have noticed, I've since removed the front drive shafts. It's not that clear in that picture, but I have a little round gear with teeth that matches the lugs in the tires. It sits in between the front and rear tires. The front tires are "driven" by the rear tires via that special gear and the super stiff lugs!!! Now that's innovation!
Glenn
Old May 21st, 2004, 09:47 AM
WOW Glenn you really put some though into this, since the fronts are driven by the rear you must have some kind of selectable locker in the rear to drive one side or the other to steer right? You must have used an axle off of a snow groomer, as they are capable of this. Is yours hydraulically controlled? Did you buy the PTO adapter from Maxi to run your hydraulics or do you use a DC motor and pump?
Old May 21st, 2004, 07:51 PM
Well we thought big was big but look at these bad boys they measure about 64"x28". Now some may say we are getting a little excessively big but you never know when you might have to drive over a house or something.
Name:	5ton tires.jpg
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
