No Spark - Defender Source
Old September 4th, 2005, 11:43 AM
No Spark
Changed cap and wires. Truck started and ran fine. Went inside to wash hands, came back out truck dead. Try to start no love.
Put back on old coil wire no love.
Put back on old cap no love.
No spark at plugs, no spark at coil. WTF.
Help.
Ron
Old September 4th, 2005, 02:28 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Ron,
Same thing happened to me 2 weeks ago. Turns out the mounting screws (which double as the ground) of the amplifier module were loose. The shop manual says that it is mounted to the side of the distributor, but mine was mounted on the back of the coil mounting bracket.
Hope this helps,
Kris
Old September 4th, 2005, 07:22 PM
Fixed it, the little connector on the negative side of the coil was making intermitent contact.
It still does not run perfect but it runs with no CEL.
Ron
Spark plug recommendations tron Defender Technical Discussions 18 March 31st, 2006 07:00 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
No Spark Billakris Defender Technical Discussions 6 August 19th, 2005 12:01 AM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
