New Rover 9in almost ready - Defender Source
Old October 27th, 2003, 12:05 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Check out the Rover 9in almost ready to drop!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 27th, 2003, 12:06 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Another
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
one more
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 27th, 2003, 12:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
last one
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 27th, 2003, 12:57 PM
that gonna be a high pinion diff?
Old October 27th, 2003, 12:59 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Nope,
It is a little known fact that the high pinion stuff is an 8.8in R+P. Strong and people have had good results but a regular 9in many feel is as strong as the D-60 r+p, just a whole heck of a lot higher off the ground and lighter.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 27th, 2003, 01:29 PM
ahhh..
Old October 27th, 2003, 08:54 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Looks sweet David Now let's see which one will break first your 9" or my Salisbury
BTW, what size gears are you going with?
World traveler
Old October 28th, 2003, 12:24 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"Looks sweet David Now let's see which one will break first your 9" or my Salisbury"
Well,
If you go with 40's, yours, if you go with 37s, mine. With the power I have and small measuring 37's it will be very hard for me to break this. Especially with all the high tech junk. As to gears we are kinda stuck between 4.37s and 4.56. I don't trailer so I want to be able to cruise at 70 without winding the motor.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 28th, 2003, 11:29 AM
redrover
Guest
Posts: n/a
drop in
Hey Buck/David, what kind of contol arm setup are you fabricating? A-arm and control arms ,or 4-link? Looks sweet.
Old October 28th, 2003, 11:37 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey,
Do you mean for the front or the rear? The rear is going to follow a stock set up with all new links made out of some nearly impossible to break junk. Very beefey. The front, well that is top secret. Part of it rymes with soilover. I will post picts soon.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 28th, 2003, 01:11 PM
comac90
Troy McNeill
Always looking...
i've had a few discussions lately with people trying to convince me that a ford 9" is as strong or stronger than a 60.
so far, i'm not convinced. so, please, if someone has a good argument, convince me....
the 9" does have a pinion support bearing (which is a great design, i might add), but that only helps with pinion deflection being a cause breakage. everything about a 60 (or Sals) r&p is bigger. assuming same materials, a 9" is going to break before a 60. anyway you cut it, a 60 is stronger. ...&, FWIW, all things being equal, my opinion is a 60 will handle 40s as well as a 9" will handle 37s.
so just for the record, here are the specs of each.
Dana 60
Ring Gear Diameter: 9 3/4
Pinion Shaft Diameter: 1.625"
Ring Gear Bolts: (12) RH Thread 1/2" X 20
Pinion Splines: 29
Cover Bolts: 10
Ring Gear Diameter: 9"
Pinion Shaft Diameter: 1.313"
Ring Gear Bolts: (10) RH Thread 7/16" X 20
Pinion Splines: 28
Cover Bolts: 10
i, also, don't get this thing of lightweight axles being a big issue on a rockcrawler outside of competition (& even then i have some questions to a point). yes, the OVERALL weight of the vehicle may make a difference as to whether or not you'll get over something. but, higher unsprung weights lower your vehicle's CG & gives you better stability.
also, you generally don't want those higher weights in the wheels because of the increased angular momentum & decrease in perceived engine power it causes .... especially on a rover. that only leaves the axles as the 'good' place to "add" unsprung weight without affecting performance.
anyone got any insight to impart?
T
Old October 28th, 2003, 01:19 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I pulled this off the web.
Why you need a Ford 9"
Although the basic bigger is better and size matters points are still strong arguments in the wheeling community, there is more to the Ford 9" than its size. The pinion is larger than the standard Dana 60, and that fact alone means more strength and less chance of damage. The Ford 9" ring gear is also thicker (although smaller in diameter) than the Dana 60 ring gear, which again, means more strength and less worry. Ground clearance is another advantage to a 9", and a shaved 9" has even greater clearance, Click here to see a comparison. Go to any NHRA, SCORE, NASCAR, or Local dirt track event and look under the rear of all of the vehicles. There is a reason drag racers and hotrod enthusiasts alike have trusted the Ford 9" for years, and here are a few of them.
Note: despite its size, the Ford 9" system is lighter than the Dana system.
Left to right: Dana 30, Dana 44, Dana 60, Ford 9" pinions On comparison of the pinions one of the first things you will notice is the additional pinion support extending from (in this picture) the lower end of the pinion. This feature helps reduce the level of stress on the pinion.
Note: the Ford 9" pinion enters the ring gear at a lower point, which also provides better strength and stability than the standard Dana 60.
The angle of the teeth on the Ford 9" pinion is at a greater degree than that of the Dana series. This creates a larger contact area on the ring gear and greater tooth engagement; the area that stress is divided over is larger which means less stress on any particular area.
Top comparison of main caps The main caps in the differential are another strong point of the Ford 9" system. They are the main link between the differential and the case on a Ford 9", or the housing and the case on a Dana. Notice the difference in size and structure between the cast iron of the Dana and the forged steel of the Ford 9" main cap.
The modular design of the Ford 9" is an often overlooked advantage. The main caps on a Dana design are an integrated part of the entire axle housing. This means that if a Dana main cap fails, the whole housing becomes worthless. The Ford drop out 3rd member (pictured below) contains the ring and pinion and the differential held in by the main caps. If the main cap fails you can replace the 3rd member and you are back on the trail.
Side comparison of main caps
Nodular Ford 3rd Member
Technical note on the rear Dana 60 reverse ring and pinion system
The problem with the 'Dana 60 reverse ring and pinion in the rear' setup is that it is literally being run backwards. These gear sets are loading on the coast side of the gear teeth when run backwards. Assuming that the axle assembly is delivering 5500 foot pounds of torque to the axles (the Dana 60's official maximum rating), the separation force exerted on the driver side carrier bearing is approximately 7300 pounds. That is ~175% of the load that would be found if the axle was used as Dana/Spicer designed it. This extreme load can cause many problems.
This is a good 9in arguement that I found. This arguement is a lot like Ford vs Chevy, which is better and there are arguements on both sides. Unsprung weight is almost never good. Especially with underpowered Defenders. Tire weight is a fighting matter. Many comp guys fill thier tires with water or sand to increase the tire weight. People should keep in mind that the most successful rock crawler of all time Jon Bundrant is running custom 9's.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 28th, 2003, 02:05 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Thumbs up
Salisbury Dana60 or Ford 9" it really doesn't matter. The point is there are two guys in the market that gave us an option besides modifying the stock D90 housing and I appreciate that
NSO and Rover Tracks guys keep up the awesome work
World traveler
Old October 28th, 2003, 02:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Totally right,
And it is important to note that my axle will be weaker than a d-60 with 35 spline axles. I have 31 spline 1.37in axles so those are the weak link for me. It will be way stronger than a stock d-60 but weaker than a pimped out d-60. Billsters is every bit as strong as any D-60 except for maybe the camo 60/40
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 28th, 2003, 02:51 PM
just about all the drag racers I have talked to run 9" thats most def worth something. do the 60's have c clips?
Old October 28th, 2003, 02:59 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I'll get back to you on that, turns out my house might be close to being burned down so I gotta go!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 28th, 2003, 07:52 PM
comac90
Troy McNeill
Always looking...
dave-
those are some great points & help to increase the general knowledge base here. i'll respond to some of those when i have some more time, but a couple of quick things....
first, be safe. you're in our thoughts & i hope everything works out with your house.
2nd, no, 60s do not have c-clips.
3rd, there was a mention of NSO & RT. its in no way my intent for this discussion to come across as a NSO vs RT thing. I personally know KC. He makes an awesome product & is a great guy. I almost even bought a Rover9 myself.
it IS my intent, though, to get some solid understanding of the differences between the 2 most popular axle conversions being done on ALL 4WD vehicles right now ... the Dana 60 & the 9".
T
Old October 28th, 2003, 11:08 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks a lot Troy,
It turns out the winds took the fires out east and north from my house. I was never that close. For a second there the news said that the wind was blowing hard west and the largest fire at that time was about 4 miles east from my house so I jammed here to grab stuf and water it down but it turned again. Few, I hope all the other San Diegans on the list are doing alright as well. Don't worry at all about any NSO Rovertrax type bad anything at all. I dig both of the options and it took a lot of time to make my decision to go where I did and I still hope I made the right choice. A whole lot of wheeling is the only way to tell for sure. I even got the Salsbury option all dialed in with GBR before heading in a different direction. A lot of the motivation for my decision was that at the time, KC had the only good option that I knew of for the front end. I was even seconds away from buying the elusive coiler front Salsbury. Plus, KC was real good to me on the phone. It came down to clearance and weight. If I ever go bigger on the tires I will will probably end up with the 35 splines then anyway! Thanks again!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 29th, 2003, 11:40 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
This is going to turn into the Pirate Thread real soon
Hee Hee
Hows the Fire Dave? Still Safe I presume? Hope so...
It's gonna be fun to get all this junk together and find that no one breaks.. What a nice trip that will be...
Really we should all find a common location (middle of some desert, for the safety of others) Order pizza and beer eat like mad drink beer enjoy a fire and realize we're all just doing the same thing only different... After loss of much breath.
Oh yeah... Last guy standing has the strongest axle...
Hee Hee..
I hope it all works as portals and Rockwells are to heavy for me to F--k with!
Later
Gotta go watch our fire now ... (only 6000 acres as of yet)
Keith
Keith
Big, Red and ... aaa Red..
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
Good Bye Ford, Hello Tata... It's done. JFD Misc. Chit-Chat 46 April 3rd, 2008 02:49 PM
Land Rover family tree D901619 Defender Technical Discussions 9 July 5th, 2007 04:34 PM
1994 Land Rover Discovery, ready for off road SBA For Sale - Vehicles 4 August 24th, 2005 11:28 AM
Expedition Ready Range Rover RedRhinoProducts For Sale - Vehicles 0 September 19th, 2004 01:12 PM
