New 110 owner - Defender Source
Old October 25th, 2010, 12:19 AM
michael67's Avatar
michael67
Michael White
110 Tdi
New 110 owner
Hi all!
I made it back from Chicago in once piece, along with an '84 ROW 110 three door with a 300 TDi & LT77. This is my first Land Rover, although I've had my '82 Scrambler since '98, so I'm no 4x4 or high maintenance noobie. I spent the weekend going over it, and everything so far seems pretty solid. Surface rust on the frame, and some minor corrosion here and there due to metal mismatch. I'm generally impressed with how well it's built, and how heavy a number of the components are compared to my Scrambler. Slightly different tool for a slightly different job. It's a world a difference jumping from one to the other.
Two things are stopping me from taking it for a Texas inspection. First, the brake pedal catches very low, and it looks to be a rear left wheel cylinder leaking combined with air in the brake lines. The left brake drum and brake components were coated with what looks to be a mixture of dust and brake fluid (i.e. nasty grease), and there was a lot of crud and dampness under the torn wheel cylinder dust boots. Should be a simple replacement. I'll be doing both wheel cylinders, even though the other's not leaking. These have the manually adjustable rear brakes - any upgrade to automatic adjustable brakes recommended while I have everything apart?
The other inspection problem is the wipers barely move on a dry windshield - they need to work and return, and they barely do so. On a slightly damp windshield, they move normally. When it starts to rain, they go nuts and start slapping the bottom of the windshield frame. I plan on following this guy's post and lubricate everything up:
http://www.landyzone.co.uk/lz/f41/wi...wal-99743.html
Any other ideas on this?
The only other mechanical issue I'm aware of is a leaking swivel housing. I'll likely fill it with the swivel housing grease until I get time to fix it properly.
Lots of other minor issues I need to address, like not all of the idiot lights were connected on the new TDi dash, the turn signal canceller only cancels at one spot, the heater/defroster motor no longer spins, etc....
Fun fun fun!
Old October 25th, 2010, 07:52 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Congratulations and welcome to the club! No secret handshakes needed here...
Email is
Same place, new dogs.
Old October 25th, 2010, 10:36 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
sounds great, got any pics?
would they fail you for that indicator stalk and wiper issue?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 25th, 2010, 08:47 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Just the pictures from the seller - it was an ebay posting from a while back as a '65:
http://cgi.ebay.com/ebaymotors/PROFE...item35ab2a7da4
Not for the turn indicator, but maybe for the wipers. They need to move and return. They don't do that so well now.
Old October 25th, 2010, 09:16 PM
JPBrown's Avatar
JPBrown
James Brown
91 & 2000-110 -93 130 wagon, 88 d90
My brother is a car dealer in Austin...if you really need it inspected he can get someone to do it.
Nice truck! We are in Austin a bit and would love to check it out next time were in town.
James
No Limit Expeditions
www.NoLimitX.com
Old October 26th, 2010, 01:08 AM
michael67's Avatar
michael67
Michael White
110 Tdi
James
www.NoLimitX.com
Thanks! I may take you up on that, although I can't imagine having too many issues once I fix the brakes (really needed) and the wipers (annoyingly needed). Everything else seems to work well. PM me a name if you like, or post it here. It'd be nice to have a "friendly" inspector.
Let me know next time you're planning on being in town!
One owner LHD 1985 V8 110 Legal For Sale JimC The Flea Market 6 July 20th, 2008 06:37 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
1993 Defender 110 mpodgorski For Sale - Vehicles 11 April 4th, 2006 07:07 PM
