never ending - Defender Source
Old May 30th, 2005, 07:07 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
never ending
Its never ending.First the transfer case needed replacing,then all 4 wheel bearings needed to be replaced,screwed up one of the seals and have grease oozing onto the discs.
Drop arm needed to be replaced and steering box had to be adjusted.
Fuel pump packed up, droped tank and fitted a new one then i found the rubber seal after putting it all back.
got to drop it again.
Snapped 4 studs on the manifold when fitting new gaskets.
Now just as i thought every thing is ok the thrust plate on the clutch goes
Old May 30th, 2005, 08:21 AM
Oh yeah whatever you don't even know! LOL Should I list everything I have done to mine? I could but it will take a while for me to type it all out.
Old June 19th, 2005, 07:33 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Got thr clutch fix,every thing running fine then it starts overheating.Then the gas pump packs up,check fuses, seems ok so drop the tank againg wires pump to battery and it works.check wiring and that seemed fine.Mike came over checked the fuses again,stupid me check the wrong fuse i was reading them upside down,fitted new 7.5 fuse refit tank and alls well.As for the overheating stripped out radiator ect now i just got to hope my new electric one comes before wed then all set for paragon.If not i can't see Mike's being fix so will just have to borrow his fans for now
Old June 19th, 2005, 11:48 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I feel your pain.
Series III 109 d90boy Wanted 14 December 30th, 2009 05:32 PM
Fuel Can Holders from Adventure Trailers (AT) trailerman The Vendors Loft 5 August 31st, 2006 01:51 PM
