Need help with a disco problem - Defender Source
Old September 29th, 2013, 04:20 PM
bearskinrug
patrick
lookin
Well I sold the D90 and picked up something a little more civilized.
I'm a new disco owner, a rust free '98 with about 86,000 miles and was pretty happy till I just filled the tank. I got to about 20 gallons and the filler started to make that sound like the tank was getting full and about to auto-stop but didn't, and gas started pouring out from under the truck, near the passenger side. I live about 2 blocks from the gas station, so I chanced it and drove home. The fuel gage took the whole 3-4 min to get to full.
There's no rust under this truck, its been a southwest truck for life. Anyone have any ideas? filler neck or some sort of hose to the tank, maybe?
Thanks for any help.
Old September 29th, 2013, 04:29 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That's one of the great things about a disco, you can see the whole filler hose from under the car, take a look!
Old September 29th, 2013, 04:40 PM
bearskinrug
patrick
lookin
Well thats a good point. So the filler neck and tube it look pretty intact and dry. The most dependent portion of the skid tank is still a little wet, and I cant feel any defects or wetness over the parts of the top of the tank I can feel. I guess I'm looking at dropping the tank? It looks so clean from the underside.....
Old September 29th, 2013, 04:51 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
If it didn't auto stop are you sure it wasn't coming out of the top of the filler?
You little rebel, I like you.
Old September 29th, 2013, 05:12 PM
bearskinrug
patrick
lookin
No I'm not, that's another good point. Maybe I'll try filling with a jerry can and watch under the truck for leaks.
Old September 29th, 2013, 11:11 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
The filler vent can be finicky depending on age and the temperature. Search on Dweb as it's a fairly common problem that it gets stopped due to clogging causing it to prematurely cut off filling. I had a Disco in Texas and whenever it was close to 100 deg outside this would happen. Moved from Texas heat and the problem was solved. It didn't cut off once while filling when it was going on and gas went everywhere.
http://www.discoweb.org/forums/showt...el+filler+neck
http://www.discoweb.org/forums/showthread.php?t=11781
Old September 30th, 2013, 05:26 PM
bearskinrug
patrick
lookin
Turns out the fuel pump wasn't screwed into the tank where it mounts. Seems like that could have been bad....
disco
Disco 2, Dash warning lights Problem JohnsD90 Defender Technical Discussions 5 October 16th, 2009 09:13 AM
'94 Disco auto transmission problem cgalpin Defender Technical Discussions 19 July 27th, 2006 10:20 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
» Defender Registry
SW 2267
ramskull
D-Storm
LI90
Add your Defender
