Need Help in Colorado - Defender Source
Old October 14th, 2015, 08:53 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I'm in grand Junction. ..lost injector on 300tdi. ... still tryin to get her goin .
516 902 1001
No Mall crawler here
Old October 14th, 2015, 09:21 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Chris:
I lined up 2 people with sets of new injectors for you when you were having trouble while in Arizona.
Steven never got a call from you.
Bill remained on standby with his new set of 4.
I never heard back from you either.
Spent a lot of my time to line up help for you that it appears you didn't take advantage of.
Still have the box containing 2 used injectors for the "plan B" in case you couldn't get a new set in the back of my 110.
Both I went to the trouble to pull out of running engines to try and help your situation.
RDavisinVA
Old October 14th, 2015, 09:38 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Yes it was 2 days before anyone contacted me have to head home she was running fine just leaking overnight ....well just diagnosed it seam as the injection pump took a shit ...no fuel ti injectors at all
Old October 14th, 2015, 09:44 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Is there (+) power to the fuel shutoff when the key is switched on?
Without the solenoid energized there will be no fuel delivery.
RDavisinVA
Old October 14th, 2015, 09:50 AM
The solenoid can also fail and get stuck closed. Pull the solenoid, remove the guts of the valve, ensure that there is no stuff in there. Reassembly without valve guts and see if it runs.
Old October 14th, 2015, 09:57 AM
And I'm working on the assumption, you have verified there is good fuel flow into the injection pump from the lift pump.
Old October 14th, 2015, 10:10 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Just did that it runs now but seams like 2 cylinders ...im sure we have injector failure ...i took them apart in hopes to clean but that didnt work ....gona find a injection service place see if we can rebuild here unless someone is in the area
ID:	132231   Click image for larger version
Old October 14th, 2015, 10:19 AM
LR Max
Thomason, Max
1973 Series 3 109
PM'd a possible shop to help in Grand Junction.
Are you getting spray? Just hook one injector outside of the engine with the other injector lines disconnected and crank the engine. You can check the spray patterns in the field easily. There should be 5 atomized jets from each nozzle. At the same time, you can verify the pump is pushing fuel to all four injectors.
Never heard of an injector completely failing before.
Old October 14th, 2015, 10:28 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I have 2 new Bosch nozzles if that will help.
RDavisinVA
Old October 15th, 2015, 08:00 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Thanks for the advice guys ..its little hard to think at 4 am in the middle of know where so Here's the update...ended up at a diesel shop where we tested re shimmed and cleaned the injectors ....there shitty but will work ...also found gas in my last fill up which pretty much rendered the 130 useless..after draining and changing filter ...she fired right up ..i went back to station to find pumps locked out explained my situation and they had no problem paying the cost for the repair and fuel ....so im contiuning on with making new friends in Colorado as my journey continues
colorado shop help Gunmaker Misc. Chit-Chat 11 October 1st, 2013 09:05 AM
Colorado People - HELP rijosho Misc. Chit-Chat 8 November 17th, 2009 07:44 PM
Colorado Diesel Help GMoe Defender Technical Discussions 4 April 9th, 2008 01:39 PM
help near boulder colorado.... beck427 Defender Technical Discussions 6 April 10th, 2007 12:40 AM
Need 4 Jump Seats in Colorado... Jim Reichers Wanted 2 September 7th, 2005 05:12 PM
