Need Advice - Defender Source
Old January 1st, 2016, 04:31 PM
RBBailey
RBBailey
1965 IIa
Need Advice
Let me explain, then let me ask a question. The last few years have been like this...
After slowly doing some refurb and update on the IIa over the course of two years, I put it all back together and two weeks later the engine loses oil pressure, and I am back to square one.
I get a replacement engine for cheap, but it checks out. I do another tear down and engine swap, put it all back together 6 months later... wait for it.... two weeks later it is knocking and oil pressure is low. I've been using whatever spare time I have to try to diagnose and hopefully find a fix... for the last year. The engine runs really well, smooth, spunky, but... that knock.
I get the Defender, it is great, runs well for 9 months, then I pull it apart and begin the slow process of refurbing it with the 300Tdi, etc. I'm kind of stuck in the middle of that project right now.
I have a great 4.2l LWB that I picked up for the express purpose of getting me through the Defender build, then I plan on mothballing it and giving it to my son as a project for him to learn on and learn to drive on a year an a half from now...... two weeks later, it is knocking badly and I'm afraid to drive it. Doesn't start well, low oil pressure on start for a good 30 seconds. No gunk in pan or oil screen.
So, I'm stuck with three Rovers. One is stripped down to the frame on the front half. The other two do run, but... Basically, I have to sacrifice one to drive to work, while the other is getting fixed. If I don't sacrifice one or the other, I have to sacrifice the Defender project and put it off for another year (because I would be doing all the work myself now) due to my budget being blown on a rental car for a couple of weeks while I get one or the other of the RRC or IIa fixed.
If you are doing the math, you may wonder how I was getting around before I got the LWB RRC -- I had a perfect 2004 DII. In 5 years of ownership the only thing that ever went wrong with it was the ABS block. Because I got the RRC, and because it was running so well, and because I was looking at the light at the end of the tunnel on the Defender build, I sold the Disco. In hind sight... well... yeah...
What would you do?
Project:
1965 IIa SWB
Old January 1st, 2016, 04:41 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Sell/part out the LWB and focus on the Defender get that shit right then tell your son the IIa is all his and the sooner he starts to figure that shit out the sooner he will be rolling with the ladies.
Old January 1st, 2016, 04:52 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
I say opposite, sell the IIa and keep the classic, your son will need a vehicle that can get him from point a-b at a speed faster than 50, eventually he will need to travel on the interstate. Or just go buy a thousand dollar beater to drive for a few weeks and then sell it.
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old January 1st, 2016, 04:54 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by RBBailey View Post
What would you do?
Luckily, I had a Lexus for years to get around in...and now a big Ford truck... while the Rover projects were under the knife.
My RR Hunter has never failed me in 10 years.
Simple fix for the LWB would be to swap in another running motor.
With an extra set of hands, a swap can be done in a weekend reasonably.
Rent my
Old January 1st, 2016, 05:08 PM
The real question is, what are you doing wrong that is causing all your engines to fail?
Are you putting additives in your crankcase oil? Are you using ultra-thin synthetics like 0W-40 or 5w-20?
Old January 1st, 2016, 05:46 PM
RBBailey
RBBailey
1965 IIa
Well, the RRC was supposed to be the beater to get me through the projects. It cost me $1000.
So it isn't a loss, it's just a headache.
I really don't want to sell either. Especially the IIa. I've owned it since 1999, already sold it once, felt bad, bought it back 3 years later.
I am using Castrol 20w50 in the Series. 10w40 in the others. I use Lucas oil stabilizer as well.
------ Follow up post added January 1st, 2016 02:48 PM ------
The problem with that is that's just what I did with the IIa... look where it got me. Also, when I bought this one, it was running really well. I'm cursed, I tell you. CURSED!
Project:
1965 IIa SWB
Old January 1st, 2016, 06:19 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I've got a D1 you can borrow until you get running...
Old January 1st, 2016, 06:54 PM
RBBailey
RBBailey
1965 IIa
That's awesome, Brian! I'd take you up on that if I was closer to you. Would be kind of a detour at this point.
Project:
1965 IIa SWB
Old January 1st, 2016, 07:34 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Want to exercise my 90ST until I get it back down to CA this summer? It's just sitting in the garage in Portland. I haven't had a chance to run it much in the past year and that's a recipe for disaster.
Old January 1st, 2016, 07:51 PM
RBBailey
RBBailey
1965 IIa
Hummmmm....
I may take you up on that idea -- I know I can drive the Series gently for a few days, and my wife and I can coordinate using one car for a day or two if we need to. So I'm able to get through this coming week. I need to get the Series or LWB in the shop to get a solid diagnosis and estimate on time/money involved.
Don't you come up and drive it while here on a regular basis? Wouldn't want to disrupt your schedule!
Project:
1965 IIa SWB
Old January 1st, 2016, 07:58 PM
D90Overkill
David Frank
1995 ST #2615
Nope. I start it and roll it every time I'm through, but have never been in town long enough to get the fuel pump replaced. I'm at <3~5lbs. If you're going to drive it, I'll have it scheduled, paid, and you can pick it up.
Just pm me if you decide to.
Old January 1st, 2016, 08:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Here's what you do...
Buy a Toyota Camary, preferably a 1990 - 1998 4 cylinder.
Drive it...
Next you pass the IIA to your son, as foundation material, as Raub suggests.
Mothball the Range Rover and save it.
Work on the Defender with all your might.
If/When you get discouraged drive to the VA/NC rallies and get stoked up to come back and succeed.
Then Enjoy, because all this is very much part of the fun.
RDavisinVA
Old January 1st, 2016, 08:14 PM
RBBailey
RBBailey
1965 IIa
Yeah, as you both point out, the IIa is so perfect for a boy -- one way or another, I'm sure he'll claim it as his over the RRC anyway.
David, I'll get in touch when I figure this out. Thanks for your generosity.
Project:
1965 IIa SWB
Old January 1st, 2016, 11:13 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Realistically, how long before your 110 is back on the road?
I was going to say dump the IIa, but it seems that's not an option.
I'd be tempted to fix the RR ASAP as a DD.
I know it sucks to drive a non-Rover, but the Honda/Toyota/Nissan idea might be worthwhile if your Rovers are all going to be fixed but it's going to take a while.
Hopefully the light at the end of the tunnel is all 3 Rovers running, but I too an concerned that there seems to be a pattern here. Sabotage? I'd be interested to hear exactly what's wrong with the engines...
Good luck whatever you decide!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old January 1st, 2016, 11:40 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Sounds to me like you and I have the same luck.
Did a diesel conversion on my D1 using the HS2.8 several years ago. Less than 8 months pass and it literally blew apart just puttin along on the highway at 1900 rpm.
I'm still trying to get it back together.
While it has been down, I bought the RR P38 Westminster to get around in. It's been down 4 months waiting for a BECM.
Public transportation sucks and so does bumming rides.
Black Rhino Lives Matter
Old January 2nd, 2016, 02:05 AM
D90Overkill
David Frank
1995 ST #2615
My pleasure. As long as you don't hit anything that can file suit, you'd be doing me a favor! ;-)
Old January 2nd, 2016, 09:12 AM
keep them all and buy a base model Honda civic, from the late 90's. they only ever need oil gas and timing belts every 100k
Old January 2nd, 2016, 11:56 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Not sure if this helps, but there's a series engine & parts FS in Boise on Craigslist.
advice
Idle problem - need advice fleabus Defender Technical Discussions 24 February 7th, 2006 06:36 PM
I need some advice- RR LWB surfd90 Defender Technical Discussions 3 February 23rd, 2005 02:11 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
Need advice on storing D90 PT94D90 Defender Technical Discussions 5 May 8th, 2004 11:54 PM
