NATO/Wolf Rims - Defender Source
Old February 13th, 2005, 05:08 PM
ronward's Avatar
ronward
Redsrover
None - sadly
NATO/Wolf Rims
My new NATOs arrived from RN this week. Nice. I sprayed them with white Rustoleum enamel, great finish but once I got them up to the truck too white. So I chose Rustoleum hard finishes enamel in Bistcuit color, perfect match. Now this is a spray enamel for appliances, indoor/outdoor metals, etc. so I figure will adhere just fine to the first coat of enamel. WRONG!
The color is now a spot on match for the Alpine White of my 90, but the finish is wrinkled in places. I intend to let them dry 24 hours or more, then sand the wrinkled spots and touch up.
Any suggestions now?
Anything is possible, with the right tools...
Old February 13th, 2005, 05:11 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Did you prime it first? If you're gonna sand it anyway you might as well drop a coat of primer on it first then spray with your Biscuit.
"It's not a Jeep"
Old February 13th, 2005, 05:35 PM
ronward's Avatar
ronward
Redsrover
None - sadly
They came primed black, I applied one coat Rustoleum enamel stark white, then finished with Rustoleum hard finished epoxy enamel in the right color. Problem is, according to my wife who also is an accomplished artist, I finished with the gloss epoxy enamel over gloss enamel without sanding the gloss off. So, I will sand them once dry, then hit them with the biscuit again.
Old February 13th, 2005, 05:51 PM
Your wife is right! You should have consulted her first. You could also use a wire brush wheel in a drill to help with the sanding, and be sure to clean off all the dust.
Old February 13th, 2005, 10:00 PM
mattdh's Avatar
mattdh
Matt Hurst
ron how about some pics after you are done?
Old February 14th, 2005, 08:57 AM
ronward's Avatar
ronward
Redsrover
None - sadly
I'll post some pics when I get them mounted up. They are good "10 footers" now, but will be blemish free once I sand and re-spray...
Old February 20th, 2005, 04:36 PM
ronward's Avatar
ronward
Redsrover
None - sadly
And the hits just keep on coming....
I've screwed the finish up something awful guys. Waited a week (just couldn't get the time) and started sanding today, with poor results. So I'm taking them over to my friends body shop tomorrow to have his guys strip/sand or whatever it takes to get a smooth finish and then prime and paint Alpine White.
He may have some sort of database of automotive paint colors, but does anyone know the paint code (DuPont or whatever) for Alpine White?
Thanks!!
Old February 20th, 2005, 04:49 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Screw paint. If you don't have tires on them yet, spring for the extra bucks and get them powdercoated by a professional shop. Let them do the prep work and the coating.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 20th, 2005, 05:47 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Good point. Anyone got the Alpine White paint code?
Old February 20th, 2005, 09:11 PM
mhill
Mike Hill
95 D90 ST / 91 RRC Hunter
Alpine White LRC456 *
http://catalog.roversnorth.com/catal..._69/page68.htm
-mike
Old February 20th, 2005, 09:22 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Thanks Mike! I had that number and assumed it was a Land Rover specific code.
rims
Tubed and Tubeless rims Glenn_Guinto Defender Technical Discussions 25 March 28th, 2010 04:23 PM
35/16/15 Super Swamper TSL Boggers & rims TDI Guy For Sale - Parts 4 October 18th, 2004 10:18 AM
4 - 285/75/16's on stock D90 rims, 98% new, also spare & carrier januconn92 For Sale - Parts 7 October 13th, 2004 10:31 AM
Steel Rims thug1313 Misc. Chit-Chat 6 September 26th, 2004 03:01 PM
what could I get for my tires and rims? Rick Carlisle Defender Technical Discussions 7 November 21st, 2003 07:24 AM
» Defender Registry
Beulah
WildBoar
Shell
toddw
Add your Defender
